    Solved N64 impossible and black screen
    6
    29
    10776
    • 33ced
      33ced last edited by
      I don't arrive to use all n64 roms (v64, z64...), black screen and call back EmulationStation.
      I tried all :
      • résolution n64, 640*480 either "DMT 4" either "CEA 1"
      • core=Gliden
        What is the problem ? Always the accepting resolution? Rpi1 B with 950Mhz is too low?????????
      Thanks
      RPI2 B - overclocked 1050 MHz - Recalbox 18/03/16 - Boitier NESPI modifié alim et boutons on/off-reset
        paradadf Staff last edited by
        n64 doesn't run on a RPi1, you need at least RPi2.
        https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
        • 33ced
          Ah OK and what is the reason? thanks
            Not enough power.
            • 33ced
              33ced last edited by 33ced
              ok thank you......I have another RPI2, I can to transfer my RPI1 SD card to RPI2 uSD card? There is a wiki/guide? thanks
              • 33ced
                I installed recalbox of my rpi2 B and always the same problem. I overclocked at high 1050Mhz and my n64 screen is 640*480 : n64.videomode=DMT 4 HDMI
                what am i doing? thanks
                  You can't use the image of a RPi1 with other Raspberry Pis than the RPi1.
                  There are tons of threads about all the things you need to be aware about n64. Video, Controllers, roms, everything! Have you tried using the search function of the forum? And looking into the wiki?
                  33ced 1 Reply Last reply Reply Quote 0
                  • 33ced
                    33ced @paradadf last edited by 33ced
                    @paradadf I installed recalbox properly, with dual boot rasbpian, not with migrating rpi1 to rpi2
                    yes i searched of this forum with n64 tag but i don't find a solution
                      paradadf Staff @33ced last edited by
                      @33ced I got that with your second message. I just wanted to leave a record if anyone reads your post and thinks they can do it.
                      Well, search better, please 😄 And the wiki has also information about it.
                      • 33ced
                        excuse me, but i searched all the site with n64 tag and i can't resolve my problem.
                        I launch mario kart (E) V1.1 (and others) and come back immediately to ES.....please help me
                          Substring @33ced last edited by
                          @33ced please SSH to your recalbox, type /etc/init.d/S31emulationstation restart, launch a N64 game and please paste here the that is displayed when crashing.
                            paradadf Staff last edited by paradadf
                            Assuming you have everything with default values...
                            1. Your n64 roms can only have one these extension (no compression!): .n64, .v64, .z64
                              https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/board/recalbox/fsoverlay/recalbox/share_init/roms/n64/_readme.txt
                            2. You must configure L and R buttons on you controller.
                              What kind of controller are you trying to use?
                              Usually, if the problem is with your controller, disconnecting ALL controllers and launching a n64 rom with the keyboard should successfully boot the game. If that does work, point #3 is irrelevant.
                            3. The default resolution might no be compatible with your TV, check:
                              https://github.com/recalbox/recalbox-os/wiki/N64-:-return-to-ES-(EN)
                            • 33ced
                              @paradadf
                              1. ok for me
                              2. usb controller nes 6 pads
                              3. ok for me
                                Are you trying to play n64 with NES pads? Really?
                                The recalbox team kindly presents... the original n64 gamepad!!!
                                alt text
                                • 33ced
                                  33ced @Substring last edited by Substring
                                  @Substring
                                  # /etc/init.d/S31emulationstation restart
                                  # lvl0: 	System "favorites" is missing name, path, extension, or command!
                                  sh: warning: setlocale: LC_ALL: cannot change locale (fr_FR.UTF-8)
                                  /bin/bash: warning: setlocale: LC_ALL: cannot change locale (fr_FR.UTF-8)
                                  # sh: warning: setlocale: LC_ALL: cannot change locale (fr_FR.UTF-8)
                                  /bin/sh: warning: setlocale: LC_ALL: cannot change locale (fr_FR.UTF-8)
                                  Traceback (most recent call last):
                                    File "/usr/share/recalbox/build/rb-4.0.X/rpi2/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 151, in <module>
                                      command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
                                    File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenGenerator.py", line 20, in generate
                                      mupenControllers.writeControllersConfig(playersControllers)
                                    File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenControllers.py", line 40, in writeControllersConfig
                                      config = defineControllerKeys(player)
                                    File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenControllers.py", line 70, in defineControllerKeys
                                      config['Z Trig'] = setControllerLine(controller.inputs['x'], "Z Trig")
                                  KeyError: 'x'
                                  @paradadf
                                  then problem with my pad :
                                  text alternatif
                                  because I remove this controller, and with the keyboard, i can play, it's ok.
                                  it's the configgen, I must configure my controller in which file ? thanks
                                    HOW IN THIS LOVING WORLD do you plan to use a NES pad for n64??? WHAT do you want to configure?
                                    33ced 1 Reply Last reply Reply Quote -1
                                    • 33ced
                                      @paradadf
                                      OK i use this controller because i have this, and i would like play only with 4-5 N64 games.
                                      I cannot with this controller or i can modify a script, a cfg file for mupenControllers? thanks
                                        acris last edited by rockaddicted
                                        For n64 you need a gamepad with more buttons like psx or xbox360 gamepad. It's not possible with a NES gamepad.
                                          You can not play N64 with a NES pad. How do you want to play on a controler that has 1 dpaf, 1 analogue stick, 10 buttons on a pad that is 30% of what is expected ? You can't.
                                          This problem will be the same with megadrive, PSX and many more emulators ...
                                          • 33ced
                                            33ced @Substring last edited by 33ced
                                            @Substring
                                            OK I see....and with which controller i can play of most of emulator (for example sees controller or n64 gamepad, it's ok for psx, n64 .....)? thanks
