    Sega arcade ... what emulator?
    Emulator Arcade/PC/Console
    sega arcade
    3493
    • foyde
      foyde last edited by
      Hi to all;
      I´m trying to play to SEGA´s classic 90´s (Golden Axe, Hang-on, etc) but the performance results are very poor (with FBA and Mame) on my Rasp 3 with v4 stable. What´s is the perfect emulator and perfect core to play this games?
      Thanks in advance;
        Hi,
        Have you tried disabling rewind in options ?
          paradadf Staff last edited by
          Have you checked the compatibility lists?
          I haven't checked mame, but I know for sure that on fba_libretro (not fba) both games you mentioned work perfectly fine on a RPi2 (tht list is for the 0.2.97.39 romset, which will be available on 4.1. 4.0 final uses the 0.2.97.37 and might have issues).
          Anyway, it is always important to be sure to that the right romset.
          foyde 1 Reply Last reply Reply Quote 0
            paradadf Staff @Substring last edited by
            @Substring hahahah... being fast isn't always a good quality! XD
            • DannyOcean
              DannyOcean last edited by
              For Sega I would go with the standard Sega Mega Drive/Genesis and Master System. Perfect.
              When it comes to arcade games I use the 0.2.97.38 romset on 4.0 final. Also works perfect with fba_libretro
              • foyde
                foyde @paradadf last edited by
                @paradadf Yes; I checked the compatibility test, and I´m triying with FBA LIbreto and this romset (0.2.97.39 ), as it says in it, and the games are pretty slow. I´ll try disabling rewind option for the emu as @Substring tells.
                Greetings
                  paradadf Staff @foyde last edited by
                  @foyde be aware that recalbox 4.0 final uses fba 0.2.97.37 and some games will not work as marked on the compatibility list for 0.2.97.39 because of that.
                  But fba_libretro must have the rewind option disabled, that's a must!
                  101.4k
