    Solved No signal on 4k-TV (HDMI)
    hdmi black screen 4k screen
    7407
    • c-f-g
      c-f-g last edited by
      I made a clean install on Raspi 2nd Edition. The Raspi is powered, yet no input signal on my 4K TV. Any suggestions?
        Raspi 2nd edition ? What do you mean ?
        • c-f-g
          The version released on feb 2015 (900MHz base, quad-core).
            voljega Banned @c-f-g last edited by
            @c-f-g just to be sure but are you sure your HDMI cable is well inserted on th Pi side ? This happened to me once although everything seemed connected from the outside
            c-f-g 1 Reply Last reply Reply Quote 0
            • c-f-g
              c-f-g @voljega last edited by
              @voljega yes it is.
                Substring @c-f-g last edited by
                @c-f-g Does it work on an other TV/monitor ?
                • c-f-g
                  No it doesn't, at least not with the same cable.
                  The cable is HDMI with network. I used it before with raspian and HDMI2DVI-adapter. It works with my windows pc plus monitor but not on the rasp with recalbox.
                  A cable with pure HDMI worked, though, but this is still an issue which needs to be resolved imo.
                    @c-f-g HDMI2DVI ... Dude read the wiki please 🙂
                    • c-f-g
                      c-f-g @Substring last edited by
                      @Substring said in No signal on 4k-TV (HDMI):
                      A link to the specific topic would be nice, although I think, that you misinterpreted my answer.
                      I just wanted to state, that the cable itself is okay and that the problem seems to be related to the plus network-thingy.
                        @c-f-g hdmi2dvi needs to disable the sound on hdmi, and it's explained on the wiki
                        c-f-g 1 Reply Last reply Reply Quote -1
                        • c-f-g
                          Man, I NEVER used HDMI2DVI with recalbox. I used it before with raspian. The information was given to state, that the cable itself is working.
                            @c-f-g said in No signal on 4k-TV (HDMI):
                            I thought it was still the case with your TV.
                            While the pi is on and plugged to your 4k TV, can you SSH to it ?
                            • c-f-g
                              Thanks for your help, but I resolved the issue as I wrote.
                              The problem seems to be, that HDMI with network does not work with recalbox.
                              A normal HDMI cable did it.
                                paradadf Staff @c-f-g last edited by paradadf
                                @c-f-g he is probably asking in order to find out why isn't that cable working.
