    New MicroSD,problem black screen on startup recalbox
    GamePad/GPIO/USB encoder
    microsdproblem startup recalbox
    • Nello Cognome
      Nello Cognome last edited by
      I buy a 64 GB micro SD,because 16 gb too small for the roms...
      then I read this post : Forum recalbox that has the same my problem,
      It solved by creating a primary.
      I do not understand 😞
      can you explain step by step what to do?
      Thank you so much
        You must use minitool to create ansingle primary partition on your SD, formatted in fat32. Check the wiki, i guess there are some tutorials
