    Remote Controller for Kodi inside Recalbox
    GamePad/GPIO/USB encoder
    remote kodi inside recalbox
    • Xamineh
      Xamineh last edited by Xamineh
      Hello,
      As I couldn't find any info on this (at least in English), I want to ask if this kind of remote controllers work with Kodi inside Recalbox:
      alt text
      Here you can find specs for 2 possible options:
      V6A Portable
      Rii i8
      Please note they are not Bluetooth but wireless, dongle included.
      So, if I plug it on the Raspberry pi, will it work? (keyboard + mouse)
        paradadf Staff @Xamineh last edited by
        @Xamineh I use the Rii Mini i8+ and it works wonderfully. It's exactly the same model as your second link, but with backlit.
        Xamineh 1 Reply Last reply Reply Quote 0
        • Xamineh
          Xamineh @paradadf last edited by
          @paradadf That is awesome news! I will try to find out if the first one works (because it looks awesome), otherwise I will get the Rii i8.
          Thanks for answering, mate!
