    50hz video output for PAL Games?
    50hz output pal
    3992
    • DerKettenhund
      DerKettenhund last edited by
      Hello,
      is it possible to output PAL Games with 50hz, so that european games have smooth scrolling?
        The question depends on your video output! Hdmi or composite ?
        • DerKettenhund
          Output is HDMI
            Change the global.videomode in recalbox.conf to a value tjat suports 50Hz
            • DerKettenhund
              Would be nice to have an option in recalbox OS, to start PAL games in 50hz, if wanted by the user.
                Substring @DerKettenhund last edited by
                @DerKettenhund i wouldn't expect such behaviour : this is screen dependant, and only CEA supports 50Hz, not DMT.
                • Genesis Gs
                  Genesis Gs last edited by
                  is it possible to do in 60Hz? the games go smoother?
                  DerKettenhund 1 Reply Last reply Reply Quote 0
                  • DerKettenhund
                    DerKettenhund @Genesis Gs last edited by
                    @Genesis-Gs
                    forcing PAL games to run in 60Hz tends to break some.
