    compile error + creating sd card
    compile target
    6573
    • starmagoo
      starmagoo last edited by starmagoo
      I want to compile RBX 4.1 for a RPi3.
      make recalbox-${arch}_defconfig cause no errors.
      make provides the following:
      make[1]: Entering directory '/git/recalbox-buildroot-rpi3/output/build/dosbox-r3989'
      make[1]: *** No targets specified and no makefile found.  Stop.
      make[1]: Leaving directory '/git/recalbox-buildroot-rpi3/output/build/dosbox-r3989'
      package/pkg-generic.mk:195: recipe for target '/git/recalbox-buildroot-rpi3/output/build/dosbox-r3989/.stamp_built' failed
      make: *** [/git/recalbox-buildroot-rpi3/output/build/dosbox-r3989/.stamp_built] Error 2
      Any ideas what I'm doing wrong? Anything missing?
      arch is set to rpi3
      • supernature2k
        supernature2k last edited by
        remove dosbox from package list in the makefile
          remove BR2_PACKAGE_DOSBOX from .config, more precisely
          • starmagoo
            Ok this works. thanks for your answer.
            Now I want to but all files to the SD-Card. In the Wiki guide there is the talk of 3 .tar.xz files.
            I have 2 .tar.xz files and 1 .img file.
            I miss the file share.tar.xz
            5521000 Sep  1 15:13 boot.tar.xz
            1297322496 Sep  1 15:14 recalbox.img
            193368100 Sep  1 15:13 root.tar.xz
            The rescue system has no directory for rpi3:
            ls -l recalbox-rescue/output/os/
            total 8
            recalboxOS-rpi1
            recalboxOS-rpi2
            Which files do I need for the sd card?
            regards
            • supernature2k
              Best is to burn the .img to your SD card with Win32DiskImager
                depends if you want to update or start a new SD from void
                • starmagoo
                  I would try both.
                  If I would start from scratch, I need to burn the img to the sd card like @supernature2k said?
                  Do I only need ´´root.tar.xz´´ for an update?
                    For an update, recalbox won't do anything if it doesn't have both the [br]oot.tar.xz in the right folder
                    Anyway, i don't know how good you know reaclbox, but if you wanna upgrade from a 4.0, the upgrade process to 4.1 is not yet fully ready. It will work, of course, but we didn't manage the update of some special files yet
                    • starmagoo
                      Ok a clean installation seams to be the best choise.
                      Thx for assistance. Installation process worked. Now I only need to port the scores and the ROM's?
                        don't expect too much support from the team, on 4.1 we are not yet finished developping it. Support will start once beta (or even alpha) starts
                        • starmagoo
                          No Problem, that's comprehensible.
                            paradadf Staff last edited by
                            Hi! I'm trying to compile the project for the very first time and after removing the dosbox package I get this error with freeimage:
                            >>> freeimage 3.16.0 Building
                            CXXFLAGS="-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -O3  -DPNG_ARM_NEON_OPT=0" CFLAGS="-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -O3  -DPNG_ARM_NEON_OPT=0" /usr/bin/make -j2 CC="/home/paradadf/recalbox-buildroot-rpi2/output/host/usr/bin/arm-buildroot-linux-gnueabihf-gcc" CXX="/home/paradadf/recalbox-buildroot-rpi2/output/host/usr/bin/arm-buildroot-linux-gnueabihf-g++" LD="/home/paradadf/recalbox-buildroot-rpi2/output/host/usr/bin/arm-buildroot-linux-gnueabihf-ld" -C /home/paradadf/recalbox-buildroot-rpi2/output/build/freeimage-3.16.0
                            /usr/bin/make -f Makefile.gnu
                            /home/paradadf/recalbox-buildroot-rpi2/output/host/usr/bin/arm-buildroot-linux-gnueabihf-gcc -s -shared -Wl,-soname,libfreeimage.so.3  -o libfreeimage-3.16.0.so ./Source/FreeImage/BitmapAccess.o ./Source/FreeImage/ColorLookup.o ./Source/FreeImage/FreeImage.o ./Source/FreeImage/FreeImageC.o ./Source/FreeImage/FreeImageIO.o ./Source/FreeImage/GetType.o ./Source/FreeImage/MemoryIO.o ./Source/FreeImage/PixelAccess.o ./Source/FreeImage/J2KHelper.o ././Source/FreeImage/MNGHelper.o ./Source/FreeImage/Plugin.o ./Source/FreeImage/PluginBMP.o ./Source/FreeImage/PluginCUT.o ./Source/FreeImage/PluginDDS.o ./Source/FreeImage/PluginEXR.o ./Source/FreeImage/PluginG3.o ./Source/FreeImage/PluginGIF.o ./Source/FreeImage/PluginHDR.o ./Source/FreeImage/PluginICO.o ./Source/FreeImage/PluginIFF.o ./Source/FreeImage/PluginJ2K.o ././Source/FreeImage/PluginJNG.o ./Source/FreeImage/PluginJP2.o ./Source/FreeImage/PluginJPEG.o ././Source/FreeImage/PluginJXR.o ./Source/FreeImage/PluginKOALA.o ./Source/FreeImage/PluginMNG.o ./Source/FreeImage/PluginPCD.o ./Source/FreeImage/PluginPCX.o ./Source/FreeImage/PluginPFM.o ./Source/FreeImage/PluginPICT.o ./Source/FreeImage/PluginPNG.o ./Source/FreeImage/PluginPNM.o ./Source/FreeImage/PluginPSD.o ./Source/FreeImage/PluginRAS.o ./Source/FreeImage/PluginRAW.o ./Source/FreeImage/PluginSGI.o ./Source/FreeImage/PluginTARGA.o ./Source/FreeImage/PluginTIFF.o ./Source/FreeImage/PluginWBMP.o ././Source/FreeImage/PluginWebP.o ./Source/FreeImage/PluginXBM.o ./Source/FreeImage/PluginXPM.o ./Source/FreeImage/PSDPa**er.o ./Source/FreeImage/TIFFLogLuv.o ./Source/FreeImage/Conversion.o ./Source/FreeImage/Conversion16_555.o ./Source/FreeImage/Conversion16_565.o ./Source/FreeImage/Conversion24.o ./Source/FreeImage/Conversion32.o ./Source/FreeImage/Conversion4.o ./Source/FreeImage/Conversion8.o ./Source/FreeImage/ConversionFloat.o ./Source/FreeImage/ConversionRGB16.o ./Source/FreeImage/ConversionRGBF.o ./Source/FreeImage/ConversionType.o ./Source/FreeImage/ConversionUINT16.o ./Source/FreeImage/Halftoning.o ./Source/FreeImage/tmoColorConvert.o ./Source/FreeImage/tmoDrago03.o ./Source/FreeImage/tmoFattal02.o ./Source/FreeImage/tmoReinhard05.o ./Source/FreeImage/ToneMapping.o ./Source/FreeImage/NNQuantizer.o ./Source/FreeImage/WuQuantizer.o ./Source/DeprecationManager/Deprecated.o ./Source/DeprecationManager/DeprecationMgr.o ./Source/FreeImage/CacheFile.o ./Source/FreeImage/MultiPage.o ./Source/FreeImage/ZLibInterface.o ./Source/Metadata/Exif.o ./Source/Metadata/FIRational.o ./Source/Metadata/FreeImageTag.o ./Source/Metadata/IPTC.o ./Source/Metadata/TagConversion.o ./Source/Metadata/TagLib.o ./Source/Metadata/XTIFF.o ./Source/FreeImageToolkit/Background.o ./Source/FreeImageToolkit/BSplineRotate.o ./Source/FreeImageToolkit/Channels.o ./Source/FreeImageToolkit/ClassicRotate.o ./Source/FreeImageToolkit/Colors.o ./Source/FreeImageToolkit/CopyPaste.o ./Source/FreeImageToolkit/Display.o ./Source/FreeImageToolkit/Flip.o ./Source/FreeImageToolkit/JPEGTransform.o ./Source/FreeImageToolkit/MultigridPoissonSolver.o ./Source/FreeImageToolkit/Rescale.o ./Source/FreeImageToolkit/Resize.o Source/LibJPEG/./jaricom.o Source/LibJPEG/jcapimin.o Source/LibJPEG/jcapistd.o Source/LibJPEG/./jcarith.o Source/LibJPEG/jccoefct.o Source/LibJPEG/jccolor.o Source/LibJPEG/jcdctmgr.o Source/LibJPEG/jchuff.o Source/LibJPEG/jcinit.o Source/LibJPEG/jcmainct.o Source/LibJPEG/jcmarker.o Source/LibJPEG/jcmaster.o Source/LibJPEG/jcomapi.o Source/LibJPEG/jcparam.o Source/LibJPEG/jcprepct.o Source/LibJPEG/jcsample.o Source/LibJPEG/jctrans.o Source/LibJPEG/jdapimin.o Source/LibJPEG/jdapistd.o Source/LibJPEG/./jdarith.o Source/LibJPEG/jdatadst.o Source/LibJPEG/jdatasrc.o Source/LibJPEG/jdcoefct.o Source/LibJPEG/jdcolor.o Source/LibJPEG/jddctmgr.o Source/LibJPEG/jdhuff.o Source/LibJPEG/jdinput.o Source/LibJPEG/jdmainct.o Source/LibJPEG/jdmarker.o Source/LibJPEG/jdmaster.o Source/LibJPEG/jdmerge.o Source/LibJPEG/jdpostct.o Source/LibJPEG/jdsample.o Source/LibJPEG/jdtrans.o Source/LibJPEG/jerror.o Source/LibJPEG/jfdctflt.o Source/LibJPEG/jfdctfst.o Source/LibJPEG/jfdctint.o Source/LibJPEG/jidctflt.o Source/LibJPEG/jidctfst.o Source/LibJPEG/jidctint.o Source/LibJPEG/jmemmgr.o Source/LibJPEG/jmemnobs.o Source/LibJPEG/jquant1.o Source/LibJPEG/jquant2.o Source/LibJPEG/jutils.o Source/LibJPEG/transupp.o Source/LibPNG/./png.o Source/LibPNG/./pngerror.o Source/LibPNG/./pngget.o Source/LibPNG/./pngmem.o Source/LibPNG/./pngpread.o Source/LibPNG/./pngread.o Source/LibPNG/./pngrio.o Source/LibPNG/./pngrtran.o Source/LibPNG/./pngrutil.o Source/LibPNG/./pngset.o Source/LibPNG/./pngtrans.o Source/LibPNG/./pngwio.o Source/LibPNG/./pngwrite.o Source/LibPNG/./pngwtran.o Source/LibPNG/./pngwutil.o Source/LibTIFF4/./tif_aux.o Source/LibTIFF4/./tif_close.o Source/LibTIFF4/./tif_codec.o Source/LibTIFF4/./tif_color.o Source/LibTIFF4/./tif_compress.o Source/LibTIFF4/./tif_dir.o Source/LibTIFF4/./tif_dirinfo.o Source/LibTIFF4/./tif_dirread.o Source/LibTIFF4/./tif_dirwrite.o Source/LibTIFF4/./tif_dumpmode.o Source/LibTIFF4/./tif_error.o Source/LibTIFF4/./tif_extension.o Source/LibTIFF4/./tif_fax3.o Source/LibTIFF4/./tif_fax3sm.o Source/LibTIFF4/./tif_flush.o Source/LibTIFF4/./tif_getimage.o Source/LibTIFF4/./tif_jpeg.o Source/LibTIFF4/./tif_luv.o Source/LibTIFF4/./tif_lzma.o Source/LibTIFF4/./tif_lzw.o Source/LibTIFF4/./tif_next.o Source/LibTIFF4/./tif_ojpeg.o Source/LibTIFF4/./tif_open.o Source/LibTIFF4/./tif_packbits.o Source/LibTIFF4/./tif_pixarlog.o Source/LibTIFF4/./tif_predict.o Source/LibTIFF4/./tif_print.o Source/LibTIFF4/./tif_read.o Source/LibTIFF4/./tif_strip.o Source/LibTIFF4/./tif_swab.o Source/LibTIFF4/./tif_thunder.o Source/LibTIFF4/./tif_tile.o Source/LibTIFF4/./tif_version.o Source/LibTIFF4/./tif_warning.o Source/LibTIFF4/./tif_write.o Source/LibTIFF4/./tif_zip.o Source/ZLib/./adler32.o Source/ZLib/./compress.o Source/ZLib/./crc32.o Source/ZLib/./deflate.o Source/ZLib/./gzclose.o Source/ZLib/./gzlib.o Source/ZLib/./gzread.o Source/ZLib/./gzwrite.o Source/ZLib/./infback.o Source/ZLib/./inffast.o Source/ZLib/./inflate.o Source/ZLib/./inftrees.o Source/ZLib/./trees.o Source/ZLib/./uncompr.o Source/ZLib/./zutil.o Source/LibOpenJPEG/bio.o Source/LibOpenJPEG/cio.o Source/LibOpenJPEG/dwt.o Source/LibOpenJPEG/event.o Source/LibOpenJPEG/./function_list.o Source/LibOpenJPEG/image.o Source/LibOpenJPEG/./invert.o Source/LibOpenJPEG/j2k.o Source/LibOpenJPEG/jp2.o Source/LibOpenJPEG/mct.o Source/LibOpenJPEG/mqc.o Source/LibOpenJPEG/openjpeg.o Source/LibOpenJPEG/./opj_clock.o Source/LibOpenJPEG/pi.o Source/LibOpenJPEG/raw.o Source/LibOpenJPEG/t1.o Source/LibOpenJPEG/t2.o Source/LibOpenJPEG/tcd.o Source/LibOpenJPEG/tgt.o Source/OpenEXR/./IlmImf/ImfAttribute.o Source/OpenEXR/./IlmImf/ImfB44Compressor.o Source/OpenEXR/./IlmImf/ImfBoxAttribute.o Source/OpenEXR/./IlmImf/ImfChannelList.o Source/OpenEXR/./IlmImf/ImfChannelListAttribute.o Source/OpenEXR/./IlmImf/ImfChromaticities.o Source/OpenEXR/./IlmImf/ImfChromaticitiesAttribute.o Source/OpenEXR/./IlmImf/ImfCompressionAttribute.o Source/OpenEXR/./IlmImf/ImfCompressor.o Source/OpenEXR/./IlmImf/ImfConvert.o Source/OpenEXR/./IlmImf/ImfCRgbaFile.o Source/OpenEXR/./IlmImf/ImfDoubleAttribute.o Source/OpenEXR/./IlmImf/ImfEnvmap.o Source/OpenEXR/./IlmImf/ImfEnvmapAttribute.o Source/OpenEXR/./IlmImf/ImfFloatAttribute.o Source/OpenEXR/./IlmImf/ImfFrameBuffer.o Source/OpenEXR/./IlmImf/ImfFramesPerSecond.o Source/OpenEXR/./IlmImf/ImfHeader.o Source/OpenEXR/./IlmImf/ImfHuf.o Source/OpenEXR/./IlmImf/ImfInputFile.o Source/OpenEXR/./IlmImf/ImfIntAttribute.o Source/OpenEXR/./IlmImf/ImfIO.o Source/OpenEXR/./IlmImf/ImfKeyCode.o Source/OpenEXR/./IlmImf/ImfKeyCodeAttribute.o Source/OpenEXR/./IlmImf/ImfLineOrderAttribute.o Source/OpenEXR/./IlmImf/ImfLut.o Source/OpenEXR/./IlmImf/ImfMatrixAttribute.o Source/OpenEXR/./IlmImf/ImfMisc.o Source/OpenEXR/./IlmImf/ImfOpaqueAttribute.o Source/OpenEXR/./IlmImf/ImfOutputFile.o Source/OpenEXR/./IlmImf/ImfPizCompressor.o Source/OpenEXR/./IlmImf/ImfPreviewImage.o Source/OpenEXR/./IlmImf/ImfPreviewImageAttribute.o Source/OpenEXR/./IlmImf/ImfPxr24Compressor.o Source/OpenEXR/./IlmImf/ImfRational.o Source/OpenEXR/./IlmImf/ImfRationalAttribute.o Source/OpenEXR/./IlmImf/ImfRgbaFile.o Source/OpenEXR/./IlmImf/ImfRgbaYca.o Source/OpenEXR/./IlmImf/ImfRleCompressor.o Source/OpenEXR/./IlmImf/ImfScanLineInputFile.o Source/OpenEXR/./IlmImf/ImfStandardAttributes.o Source/OpenEXR/./IlmImf/ImfStdIO.o Source/OpenEXR/./IlmImf/ImfStringAttribute.o Source/OpenEXR/./IlmImf/ImfStringVectorAttribute.o Source/OpenEXR/./IlmImf/ImfTestFile.o Source/OpenEXR/./IlmImf/ImfThreading.o Source/OpenEXR/./IlmImf/ImfTileDescriptionAttribute.o Source/OpenEXR/./IlmImf/ImfTiledInputFile.o Source/OpenEXR/./IlmImf/ImfTiledMisc.o Source/OpenEXR/./IlmImf/ImfTiledOutputFile.o Source/OpenEXR/./IlmImf/ImfTiledRgbaFile.o Source/OpenEXR/./IlmImf/ImfTileOffsets.o Source/OpenEXR/./IlmImf/ImfTimeCode.o Source/OpenEXR/./IlmImf/ImfTimeCodeAttribute.o Source/OpenEXR/./IlmImf/ImfVecAttribute.o Source/OpenEXR/./IlmImf/ImfVersion.o Source/OpenEXR/./IlmImf/ImfWav.o Source/OpenEXR/./IlmImf/ImfZipCompressor.o Source/OpenEXR/./Imath/ImathBox.o Source/OpenEXR/./Imath/ImathColorAlgo.o Source/OpenEXR/./Imath/ImathFun.o Source/OpenEXR/./Imath/ImathMatrixAlgo.o Source/OpenEXR/./Imath/ImathRandom.o Source/OpenEXR/./Imath/ImathShear.o Source/OpenEXR/./Imath/ImathVec.o Source/OpenEXR/./Iex/IexBaseExc.o Source/OpenEXR/./Iex/IexThrowErrnoExc.o Source/OpenEXR/./Half/half.o Source/OpenEXR/./IlmThread/IlmThread.o Source/OpenEXR/./IlmThread/IlmThreadMutex.o Source/OpenEXR/./IlmThread/IlmThreadPool.o Source/OpenEXR/./IlmThread/IlmThreadSemaphore.o Source/LibRawLite/./internal/dcraw_common.o Source/LibRawLite/./internal/dcraw_fileio.o Source/LibRawLite/./internal/demosaic_packs.o Source/LibRawLite/./src/libraw_c_api.o Source/LibRawLite/./src/libraw_cxx.o Source/LibRawLite/./src/libraw_datastream.o Source/LibWebP/./src/dec/dec_alpha.o Source/LibWebP/./src/dec/dec_buffer.o Source/LibWebP/./src/dec/dec_frame.o Source/LibWebP/./src/dec/dec_idec.o Source/LibWebP/./src/dec/dec_io.o Source/LibWebP/./src/dec/dec_layer.o Source/LibWebP/./src/dec/dec_quant.o Source/LibWebP/./src/dec/dec_tree.o Source/LibWebP/./src/dec/dec_vp8.o Source/LibWebP/./src/dec/dec_vp8l.o Source/LibWebP/./src/dec/dec_webp.o Source/LibWebP/./src/dsp/cpu.o Source/LibWebP/./src/dsp/dec.o Source/LibWebP/./src/dsp/dec_clip_tables.o Source/LibWebP/./src/dsp/dec_neon.o Source/LibWebP/./src/dsp/dec_sse2.o Source/LibWebP/./src/dsp/enc.o Source/LibWebP/./src/dsp/enc_neon.o Source/LibWebP/./src/dsp/enc_sse2.o Source/LibWebP/./src/dsp/lossless.o Source/LibWebP/./src/dsp/upsampling.o Source/LibWebP/./src/dsp/upsampling_neon.o Source/LibWebP/./src/dsp/upsampling_sse2.o Source/LibWebP/./src/dsp/yuv.o Source/LibWebP/./src/enc/enc_alpha.o Source/LibWebP/./src/enc/enc_analysis.o Source/LibWebP/./src/enc/enc_backward_references.o Source/LibWebP/./src/enc/enc_config.o Source/LibWebP/./src/enc/enc_cost.o Source/LibWebP/./src/enc/enc_filter.o Source/LibWebP/./src/enc/enc_frame.o Source/LibWebP/./src/enc/enc_histogram.o Source/LibWebP/./src/enc/enc_iterator.o Source/LibWebP/./src/enc/enc_layer.o Source/LibWebP/./src/enc/enc_picture.o Source/LibWebP/./src/enc/enc_quant.o Source/LibWebP/./src/enc/enc_syntax.o Source/LibWebP/./src/enc/enc_tree.o Source/LibWebP/./src/enc/enc_vp8l.o Source/LibWebP/./src/enc/enc_webpenc.o Source/LibWebP/./src/enc/token.o Source/LibWebP/./src/utils/alpha_processing.o Source/LibWebP/./src/utils/bit_reader.o Source/LibWebP/./src/utils/bit_writer.o Source/LibWebP/./src/utils/color_cache.o Source/LibWebP/./src/utils/filters.o Source/LibWebP/./src/utils/huffman.o Source/LibWebP/./src/utils/huffman_encode.o Source/LibWebP/./src/utils/quant_levels.o Source/LibWebP/./src/utils/quant_levels_dec.o Source/LibWebP/./src/utils/random.o Source/LibWebP/./src/utils/rescaler.o Source/LibWebP/./src/utils/thread.o Source/LibWebP/./src/utils/utils.o Source/LibWebP/./src/mux/muxedit.o Source/LibWebP/./src/mux/muxinternal.o Source/LibWebP/./src/mux/muxread.o Source/LibJXR/./image/decode/decode.o Source/LibJXR/./image/decode/JXRTranscode.o Source/LibJXR/./image/decode/postprocess.o Source/LibJXR/./image/decode/segdec.o Source/LibJXR/./image/decode/strdec.o Source/LibJXR/./image/decode/strdec_x86.o Source/LibJXR/./image/decode/strInvTransform.o Source/LibJXR/./image/decode/strPredQuantDec.o Source/LibJXR/./image/encode/encode.o Source/LibJXR/./image/encode/segenc.o Source/LibJXR/./image/encode/strenc.o Source/LibJXR/./image/encode/strenc_x86.o Source/LibJXR/./image/encode/strFwdTransform.o Source/LibJXR/./image/encode/strPredQuantEnc.o Source/LibJXR/./image/sys/adapthuff.o Source/LibJXR/./image/sys/image.o Source/LibJXR/./image/sys/strcodec.o Source/LibJXR/./image/sys/strPredQuant.o Source/LibJXR/./image/sys/strTransform.o Source/LibJXR/./jxrgluelib/JXRGlue.o Source/LibJXR/./jxrgluelib/JXRGlueJxr.o Source/LibJXR/./jxrgluelib/JXRGluePFC.o Source/LibJXR/./jxrgluelib/JXRMeta.o -lstdc++
                            /home/paradadf/recalbox-buildroot-rpi2/output/host/usr/lib/gcc/arm-buildroot-linux-gnueabihf/4.9.3/../../../../arm-buildroot-linux-gnueabihf/bin/ld: ./Source/FreeImage/BitmapAccess.o: relocation R_ARM_MOVW_ABS_NC against `__pthread_key_create' can not be used when making a shared object; recompile with -fPIC
                            ./Source/FreeImage/BitmapAccess.o: error adding symbols: Bad value
                            collect2: error: ld returned 1 exit status
                            Makefile.gnu:69: recipe for target 'libfreeimage-3.16.0.so' failed
                            make[3]: *** [libfreeimage-3.16.0.so] Error 1
                            Makefile:21: recipe for target 'default' failed
                            make[2]: *** [default] Error 2
                            package/pkg-generic.mk:195: recipe for target '/home/paradadf/recalbox-buildroot-rpi2/output/build/freeimage-3.16.0/.stamp_built' failed
                            make[1]: *** [/home/paradadf/recalbox-buildroot-rpi2/output/build/freeimage-3.16.0/.stamp_built] Error 2
                            Makefile:36: recipe for target '_all' failed
                            make: *** [_all] Error 2
                            Any ideas?
                              Substring @paradadf last edited by
                              @paradadf Had that on my very first compilations too using virtual box. Switching to native Linux did the trick
                                paradadf Staff @Substring last edited by
                                @subs I installed Ubuntu 16.04 32bit on an old laptop specially to try this :S
                                  @paradadf can't check for now what i'm thinking about. But the idea is to edit CCFLAGS or LDFLAGS in the package and force -fPIC. Or in the makefile even ... Buildroot is supposed to handle that itself, so i think you may encounter this problem again later in the building process
                                  • digitaLumberjack
                                    Could you test with the docker build @paradadf ?
                                    https://github.com/recalbox/recalbox-docker-build
                                      paradadf Staff @digitaLumberjack last edited by
                                      @digitaLumberjack I'll try it tonight, thanks!
                                        Hmmm... it seems I won't be able to compile it with the docker. I'm using Ubuntu 16.04 32bit and just read this on the docker documentation:
                                        Docker requires a 64-bit installation regardless of your Ubuntu version.
                                        Saldly, my old laptop doesn't support it.
