    HDMI vs CRT ,a request .
    hdmi crt request
    3993
    • jose-manuel-perez
      jose-manuel-perez last edited by
      I'm trying Retropie and Recalbox and a difference is that with Retropie 2.6 automatically detects if I have connected the raspberry to a TV via HDMI or RCA (composite) with Recalbox can not, Are you going to solve this problem in future versions? Thanks ,Regards
      • digitaLumberjack
        Hi, https://github.com/digitalLumberjack/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN) Remove hdmi_drive=2 in config.txt, that's all
        • jose-manuel-perez
          Not working ,delete the hdmi_drive=2 line in config.txt , plug a rca(composite cable ) and not work. I have this config.txt file:
          • imaster
            imaster last edited by
            If you just want to use recalbox with the composite output, here is my file /boot/config.txt:
            # uncomment if you get no picture on HDMI for a default "safe" mode
            #hdmi_safe=1
            disable_overscan=0
            # uncomment to force a specific HDMI mode (this will force VGA)
            #hdmi_group=1
            #hdmi_mode=1
            # comment to get jack audio
            #hdmi_drive=2
            #config_hdmi_boost=0
            #hdmi_force_hotplug=0
            # uncomment to ignore hdmi plug
            hdmi_ignore_hotplug=1
            # uncomment for composite PAL
            sdtv_mode=2
            # Overclock
            gpu_mem=512
            avoid_safe_mode=1
            kernel=zImage
            # NOOBS Auto-generated Settings:
            #hdmi_force_hotplug=1
            #config_hdmi_boost=4
            #overscan_left=24
            #overscan_right=24
            #overscan_top=16
            #overscan_bottom=16
            disable_overscan=0
            overscan_scale=1
            You have to comment some lines (with hdmi mention).
            • jose-manuel-perez
              I want to use the recalbox on a hdmi and crt TV ,without edit the config.txt , like a retropie 2.6 iMaster ,with your config.txt works on crt but not work in a HDMi tv.
              • imaster
                Okay. This is not possible for now.
                • hstampfl
                  hstampfl last edited by
                  Only for clarification: you would like to choose CRT or HDMI. so, they are not connected both at the same time?
                  I started my retro passion in 1985 with my C64.....Today I have a small (retro) console collection including NES, SNES, N64, GC, Wii, WiiU, GB, GBC, GBA, NDS, DSi, 3DS, 3DS XL, 2DS, NEW 3DS, SMS, SMD, SG, SD, XBOX, XBOX360, XBOX ONE, PSone, PS2, PS3, PS4, PSP, PS VITA, VECTREX, C64, AMIGA 600, MIST Board, Turbo Chamäleon
                  • retrojunkie58
                    retrojunkie58 last edited by
                    For me it is working without a problem. I have the following config atm. When hdmi is connected at boot it uses hdmi If rca is connected at boot it uses rca. Just be sure to delete the noobs autogenerated settings at the bottom of the config file. For overscanning i just use the overscan option in the recalbox emulationstation settings. ---- disable_overscan=0 sdtv_mode=2 hdmi_group=1 hdmi_mode=16 #Overclock# gpu_mem=256 arm_freq=1100 sdram_freq=500 core_freq=500 over_voltage=5 temp_limit=75 ### kernel=zImage disable_overscan=0 overscan_scale=1
