    Activating GPB7 (R2 / SIG) on MCP23017 for coin acceptor
    GamePad/GPIO/USB encoder
    activating gpb7 sig mcp23017 coin
    • slayeryea
      slayeryea last edited by
      Hello,
      I've installed the mk_arcade_joystick_rpi and I see that GPB7 which is used for coin acceptor on MCP23017 was not activated.
      Where is the setting file to enable that? I have to activate GPB7 for coin acceptor on the MAME
      Thanks
        the coin is mapped on select. Are you having trouble with that ?
        • digitaLumberjack
          The mk gpio driver of the recalbox doesn't support mcp23017. You might recompile the master branch of https://github.com/recalbox/mk_arcade_joystick_rpi in recalbox to have it enabled.
          Or develop on 4.1 a switch for the gpio drivers
          slayeryea 1 Reply Last reply Reply Quote 0
          • slayeryea
            slayeryea @digitaLumberjack last edited by
            @digitaLumberjack so how should i connect the coin mech to standard GPIO (https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(EN))?
            Thanks
            • digitaLumberjack
              Don't know.
