    Unsolved How to change time zone?
    zone
    8
    11
    13320
    • DJC
      DJC last edited by
      Can someone here explain how can I change the time zone, I live in Brazil and would like to put the correct time zone on my system. Thanks
        HELLO
        In recalbox.conf : https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
        system.language=en_US
        ;system.kblayout=us
        ## Set you local time
        system.timezone=Europe/Paris
        DJC 1 Reply Last reply Reply Quote 1
        • DJC
          DJC @acris last edited by
          @acris Got it, but what should I put in system.timezone=
          • DjLeChuck
            DjLeChuck last edited by
            One of this:
            Brazil/Acre
            Brazil/DeNoronha
            Brazil/East
            Brazil/West
            • digitaLumberjack
              digitaLumberjack Staff last edited by digitaLumberjack
              List of timezones : https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
              • DJC
                DJC last edited by
                Didn't work.
                Tryed Brazil/East
                Brazil/West
                América/Sao_Paulo
                • Robson Maniasso
                  Robson Maniasso last edited by
                  timezone is not set in recalbox.conf. I found a way to set to Brazil.
                  1 - Remount your / filesystem to read-write
                  mount -o remount,rw /
                  2 - Unkink the /etc/localtime since it is set to Europe/Paris
                  unlink /etc/localtime
                  3 - create new symbolic link to Brazil/Sao_Paulo
                  ln -s /usr/share/zoneinfo/America/Sao_Paulo localtime
                  And finally type date to see your new timezone
                  date
                  Thu Sep 15 17:27:03 BRT 2016
                  Hope this helps.
                    Substring @Robson Maniasso last edited by
                    @Robson-Maniasso said in How to change time zone?:
                    Why didn't you just try system.timezone=America/Sao_Paulo instead of your trick ?
                    RodsBrito 1 Reply Last reply Reply Quote 0
                    • RodsBrito
                      RodsBrito @Substring last edited by
                      @subs I've tryed it, but did not work
                      • blackmagik
                        blackmagik last edited by
                        What worked for me was changing it in kodi. It affected the rest of the system that way. Start up kodi, settings/appearance/international/timezone.
                        May work for you but best of luck~
                        • RodsBrito
                          RodsBrito @blackmagik last edited by
                          @blackmagik you're right. kodi is the best way. my time zone isn't correct, put I think it's because of summer time. I'll try to solve this. Thanks.
