    Custom GPIO Pin Config
    gpio pin config
    • evansrg
      evansrg last edited by
      Re: Custom GPIO pin config
      Hi. I have also been trying to use custom GPIO pin configs in Recalbox with no success. I'm trying to use the map=5 GPIO=20,23,9,etc command and it crashes recalbox. I think it might be because the mk arcade joystick package in recalbox is not the latest one. Does anybody know how to update it? Any help would be greatly appreciated!
        Custom pins are not implemented in recalbox as far as i remember.
        You would need to recompile the ko
        • malkie
          malkie last edited by
          Has this feature been implemented yet? I have tried every config I can and it isn't loading with the custom pin config.
          I would prefer not to have to get out my soldering iron 😞
          • ian57
            ian57 Staff last edited by
            As @Substring said, in RB 4.0 the custom pin config is not yet implemented. You'll need to recompile the mk_arcade_joystick_hotkey module in its last release to get this feature.
