    Solved [SOLVED] How to configure several Same-Name-Controllers, Chinaware in recalbox
    GamePad/GPIO/USB encoder
    beginner does recalbox remembers layout
    19787
    • Braxtor
      Braxtor last edited by
      Thanks.
      Yes, but if I make configs for a SNES-controller for example and use the global.configfile variable instead of snes.configfile then the controller layout also applies to NES, PSX, etc. or not? If yes, can you tell me why that makes sense? Because each emulator like PSX, NES, etc. have his own controller.
      For me: NES, PSX, etc. are emulators and this was your post:
      @subs said in [SOLVED] How to configure several No-Name-Controllers, Chinaware with the same name in recalbox:
      Tjat's a recalbox parameter file, not retroarch.
      If you use the global keyword, it means that you force custom configs for ALL emulators, even non retroarch ones (mupen, kodi, moonlight, scummvm)
        NO. specifying a configfile means that the autoconfiguration will be disabled. You can make it for a single system, or blindly for the whole recalbox.
        100.2k
