    Recalbox 9.2.1 N64 Controller problem
    Emulator Arcade/PC/Console
    recalbox 9.2.1
    • adam0509
      adam0509 last edited by adam0509
      So I updated to version 9.2.1
      Reset the config
      (fyi, I have a PowerA Xbox360 controller)
      Everything work on other emulator.
      On N64 nothing works with "MupenGlideMk2". On "Parallel" emulator it's ok.
      I dig in the system file. I use an old "InputAutoCfg.ini" file, now it works.
      (file is located in /recalbox/share/system/configs/mupen64)
      But :
      • I have Z on Select button
      • I have Start on L3 button
      Everything was working on 9.1... what happened ? 😢
      • adam0509
        Ok solved it
        This concern is for the PowerA Xbox One Controller
        It is labeled PowerA Xbox One Series X Controller in the config for some reason (?)
        Button configuration on windows :
        1 = A
        2 = B
        3 = X
        4 = Y
        5 = LB
        6 = RB
        7 = Select
        8 = Start
        9 = L3
        10 = R3
        11 = Xbox Guide
        12 = Share
        Button configuration on Linux/Recalbox :
        0 = A
        1 = B
        2 = X
        3 = Y
        4 = LB
        5 = RB
        6 = Select
        7 = Start
        8 = L3
        9 = R3
        10 = Xbox Guide
        11 = Share
        This is the correct configuration to add to InputAutoCfg.ini :
        [PowerA Xbox Series X Controller]
        A Button=button(0)
        AnalogDeadzone=4096,4096
        AnalogPeak=32768,32768
        B Button=button(2)
        C Button D=axis(4+) button(1)
        C Button L=axis(3-) button(3)
        C Button R=axis(3+)
        C Button U=axis(4-)
        DPad D=hat(0 Down)
        DPad L=hat(0 Left)
        DPad R=hat(0 Right)
        DPad U=hat(0 Up)
        L Trig=button(4)
        Mempak switch=button(11)
        R Trig=button(5)
        Rumblepak switch=button(12)
        Start=button(7)
        X Axis=axis(0-,0+) axis(0+,0-)
        Y Axis=axis(1-,1+) axis(1+,1-)
        Z Trig=axis(2+)
        mouse=False
        plugged=True
        plugin=2
