    [Question] Recalbox on crossover cable
    [question] recalbox crossover cable
    6348
    • PumpKHeaD
      PumpKHeaD last edited by
      It's possible to connect the Raspberry Pi with Recalbox as a direct on PC with a crossover or normal ethernet cable?
      This would solve the slowness to copy large files by wifi, like PSX ISO's for exemple.
      This video shows how do on Raspbian, but I have problems with sudo commands on Recalbox.
      Appreciate a little help.
        A crossover over cable would't help, the pi ethernet is slow. If you want to manage your roms transfer an other way, use a usb key 🙂
        • PumpKHeaD
          Thank's the help @subs. With a usb key option, I can only do from the command line?
            Do what from the command line ?
            • Nachtgarm
              Nachtgarm @PumpKHeaD last edited by
              @PumpKHeaD Check this please: https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
              • PumpKHeaD
                Thank you @Nachtgarm, I used this option before, but so I have to keep the USB stick in Raspberry Pi all the time, and my SD cards have more space then my USB sticks. ^^'
                I look for a way to copy to the SD card more faster. I think it'll just be able to do this using the SD card on linux.
                • Nachtgarm
                  @PumpKHeaD Is it really that slow? I mean when I copy PSX Games via WiFi to my PI I get about 2-4 MB/s, which is a OK Speed for a little Computer like this 😉
                  • PumpKHeaD
                    PumpKHeaD last edited by PumpKHeaD
                    Yes, really slow, 54kb/s. impossible copy a game of 40MB, imagine with 700mb. I begin to think that my wifi adapter is not good 😕 ... Use pi2 yet
                    • Nachtgarm
                      @PumpKHeaD That is insanely slow... What RPi do you have? I never drop down to less than 2 MB/s on my Pi2 (with WiFi Dongle) and my RPi3
                      • PumpKHeaD
                        Use a RPi2 with generic WiFi dongle. Something is very wrong here, I need to fix this 😐 So I asked how to connect the RPI directly on pc...
                        • Nachtgarm
                          @PumpKHeaD Why don't you connect your Pi to your Router and try it via cabled Network instead of having to buy a Crossover Cable and dealing with the hassle of confguring your PC and you PI to static IP adresses, etc?
                          • PumpKHeaD
                            Only because my router is far from my desktop and placed in a high place. But I will find a way to fix this. And is not the distance the problem with wifi, because I use on the pc, smartphones...
                            Thank's try help me with this 🙂
                            • PumpKHeaD
                              I could solve part of my problems with this Wiki here:
                              https://github.com/recalbox/recalbox-os/wiki/Copy-roms-from-a-Computer-to-the-SD-Card-using-an-USB-Stick-(or-External-Hard-Drive)-(EN)
                              If someone has the same problem [with a tip about 4.1] 😉
