    PPSSPP gamepad d-pad controls wrong
    GamePad/GPIO/USB encoder
    ppsspp gamepad d-pad controls wrong
    • SilverGreen93
      SilverGreen93 last edited by SilverGreen93
      Hi,
      Although I configured my USB controller (SNES-style) with the correct buttons in the Recalbox menu, when starting PPSSPP emulator, the D-pad does not work.
      I investigated a bit, and it seems that the PPSSPP emulator wrongly assigns the mapping for the D-pad. If I remap the controls in the hotkey+B menu, the controller works, but if I quit the emulator and restart again, the mapping is again lost and it will need to be reconfigured again.
      How can I fix this issue permanently? Either, PPSSPP should remember the settings OR best, the mapping should correspond to the one in recalbox configuration to begin with.
      My setup: Raspberry Pi 4 8GB, SSD boot, Recalbox 9.1
      See the attached pictures with the initial configuration and the correct one.
      Default config:
      wrong
      Correct config:
      alt text
