    Hide unwanted Files
    hide unwanted
    1918
    • Cellcon
      Cellcon last edited by
      Hello,
      I'm using the PC Version of Recalbox 9.1 and I got a Problem.
      In the Gamelist, Recalbox shows all Files that are in a Folder.
      Example:
      In Shared/Roms(internal)/Dreamcast I got a Folder named "Daytona USA"
      In the Folder, there are the Files
      Dayton USA.gdi
      track01.bin
      track02.raw
      track03.bin
      Recalbox 9.1 shows in the Gamelist ALL the Files (GDI,Bin,Raw) in the Folder, Recalbox 6.0 for Example only shows the Dayton USA.gdi File.
      So is there a possibility that Recalbox 9.1 only shows the Dayton USA.gdi File in the Gamelist too ?
      In the old Versions of Recalbox there was the possibility to edit the es_systems.cfg file to hide files, but so far that I know you can do that in the new Versions of Recalbox anymore.
      Why is this so ?
      Did I have to hide the unwanted Files by Hand now ?
      Did you know how much Work this will be for over 200 Games ?
      Or is there maybe a Way (I can't find any) to hide these unwanted Files automatically
      RustyMG 1 Reply Last reply Reply Quote 0
      • Cellcon
        Schön das man nach 5 Tagen noch nicht mal eine Antwort vom "Recalbox-Team" bekommt.
        IHR habt die Software entwickelt, also helft auch wenn Leute Probleme damit haben !
        Was ist sonst der Sinn dieses Forums ?
        • RustyMG
          RustyMG @Cellcon last edited by
          @Cellcon I just scraped my games with ARRM on my PC, and ticked the hide options to automatically hide all none "game" files.
          Simple to do, and takes just minutes.
          My setup:
          https://youtu.be/enpaoXC49Wg
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
          Cellcon 1 Reply Last reply Reply Quote 0
          • Cellcon
            Cellcon @RustyMG last edited by
            Toll was das "Recalbox-Team" mit Version 9.1 hier wieder abliefert.
            1. Es werden Dateien (z. B. RAW,BIN) angezeigt, die gar nicht angezeigt werden sollen ((Unter anderem auch mit ARRM überprüft)
            2. Preinstallierte Spiele kann man nicht mehr löschen, blendet man die Spiele über die entsprechende Funktion im Menü aus, so werden die Spiele nach einem Neutstart des Systems trotzdem angezeigt. Ein Fehler der übrigens wohl schon in Recalbox 8 existiert hat.
            Da frag' ich mich doch, ob bei diesem Programm irgendein Beta-Test stattfindet, und wenn ja, wie man diese groben Fehler übersehen kann !
            • Cellcon
              Cellcon @Cellcon last edited by
              @RustyMG
              1. I didn't use a Rasberry Pi4 I use a PC.
              2. The unwanted Files only show up in Recalbox and not in ARRM.
              • RustyMG
                @Cellcon
                1. it makes no difference
                2. that is EXACTLY why I said use ARRM.
                  It will automarically hide the files in the. xml file for you, so they no longer appear in Recalbox.
                • Cellcon
                  @RustyMG
                  Once again:
                  The UNWANTED Files (RAW, BIN and OTHERS) DIDN'T SHOW UP in ARRM.
                  There ONLY THE GAMEFILES (ISO, GDI, CHD, CUE and OTHERS) SHOW UP and I can scrape them.
                  Than IN RECALBOX THESE FILES SHOW UP with the scraped Gameinfo TOGETHER with the UNWANTED FILES.
                  To make it short:
                  The unwanted Files SHOW UP ONLY IN RECALBOX and NOT IN ARRM !
                  Cellcon RustyMG 2 Replies Last reply Reply Quote 0
                  • Cellcon
                    Cellcon @Cellcon last edited by Cellcon
                    So, Problem gelöst.
                    Habe alle meine Dreamcast-GDI Spiele mitsamt den dazugehörigen Dateien (BIN, RAW) in eine CHD-Datei umgewandelt, die wie gewünscht in Recalbox erscheint und sich (entweder mit Recalbox 9.1 oder ARRM) scrapen lässt.
                    Warum soll ich mich noch groß mit Problemen, die andere verursacht haben, noch lange herumschlagen, vor allem wenn diese Leute dann selbst nicht helfen wollen.
                    Also Leute, wenn ihr keine Franzosen seit, bei Problemem hier lieber nicht fragen, den Antwort bekommt man, wie man hier sehen kann, vom "Recalbox-Team" nicht.
                    • RustyMG
                      @Cellcon apologies.
                      Boot up ARRM
                      Untick the "hide .bin . dat" option so ALL the files show.
                      Highlight all those unwanted files, right click, choose "mark as hidden", job done.
                      If you then save out that xml file, they wont show in Recalbox.
                      I had to do that years back with all the "extra" files in my CD32 collection.
