    [SOFT] dynquee: dynamic marquee for Recalbox
    Community projects
    [soft] dynquee dynamic marquee recalbox
    21
    89
    33303
    • toniosj
      toniosj Spanish moderator @poppadum last edited by
      @poppadum Using the same graphic card and two output (HDMI and DVI), Recalbox runs with very significant fps drops.
      Using integrated graphic card for marquee, and NVIDIA for Recalbox, fps at 60 always.
      • persichini
        persichini last edited by
        I read through the tread and i've seen one message mention Raspberry Pi 5, but nothing in the office documentation.
        Is there any special requirements to getting this installed and working on a Pi5?
        Also what is the minimum resolution requirements for the second screen.
        poppadum 1 Reply Last reply Reply Quote 0
        • poppadum
          poppadum @persichini last edited by
          @persichini said in [SOFT] dynquee: dynamic marquee for Recalbox:
          I don't have a Pi5 to test with but it should work exactly the same as on a Pi4, as the Pi5 has two HDMI outputs.
          No particular minimum resolution as you can resize your marquee images to suit the screen you're using. If the Pi can recognise the screen it should be fine.
          For testing I used an old TV with 1366x768 resolution, so if you have a spare monitor you could test with that. Most of the marquee images on the internet seem to be approx 1280x360.
          • Referenced by  M__a__a__x M__a__a__x
          • deep
            deep @poppadum last edited by deep
            @poppadum said in [SOFT] dynquee: dynamic marquee for Recalbox:
            Hi @Colywobbles
            I don't have either an RBGpi or RGBDual to test with but it's likely those are the reason it's not working as intended.
            On a Pi 4/5 with 2 displays connected to the HDMI ports, both screens share a single framebuffer device. dynquee uses the fbv2 command to display an image on the framebuffer. This means marquee images are shown on both screens briefly when an emulator launches or exits. While a game emulator is running it writes directly to the first display so you see the game running on display 1 and the marquee image on display 2.
            My guess is that the RGB devices are interfering somehow. To debug you could connect to your Recalbox via ssh and stop EmulationStation and dynquee by pasting in these commands:
            es stop
            /etc/init.d/S32dynquee stop
            then test if you can get an image to display with
            fbv2 /recalbox/share/dynquee/media/startup/startup.01.png
            It could also be useful to run
            ls -l /dev/fb*
            and let me know what the result is.
            Bonjour, tout d'abord, merci pour ce projet !
            Une réponse aux essais demandés ci-dessus ?
            J'ai essayé de le mettre en place, pour 2 bornes (écran crt) avec des Recalbox RGB Jamma, (Raspberry pi 5). Sans succès malheureusement. J'ai installé sur le le RGB Jamma, mais j'ai aucune sortie vidéo sur les hdmi. Je me suis dit que ces sorties sont peut-être désactivées par Recalbox, du coup j'ai essayé avec un contrôle à distance sur un rpi 2. Mais bien que Dynquee trouve le RGB Jamma dans le réseau, il ne semble pas recevoir les commandes pour changer les images, il n'y a que les images du dossier startup qui défilent. Y aurai-t-il une nouvelle version ou méthode pour le faire fonctionner sur le RGB Jamma ? Je peux faire des essais si ça peut aider.
            Merci pour toute aide.
            • nounourspsx
              nounourspsx last edited by
              un gros bravo pour le projet c'est incroyable, il faut intégrer cela à RECALBOX !!!!
              Rapsberry Pi3; boitier 9 SAMRZA, alim SMARZA 2.5 A avec switch, 3 dissipateurs et ventilo SAMRZA; carte µSD SANDISK Ultra cl 10 16Go; HDD WDC 250Go boit. Techyo alimenté; manette Saitek Cyborg Rumble V2 & 8bitDo NES30 & 8bitDo ZERO
              • Starcom
                Starcom last edited by
                Bonjour @poppadum ,
                Je cherchais un moyen d'ajouter un marquee dynamique à ma borne Recalbox et ton projet semble y répondre.
                Mais concernant le matériel, au cours de mes recherches, je suis tombé sur un forum qui montre une idée que je trouve géniale:
                Utiliser un écran normal pour simuler un double marquee dynamique: https://www.gamoover.net/Forums/index.php?topic=32889.32
                alt text
                On fixe une fausse bordure et un faux T-molding.
                On peut ensuite afficher un marquee dynamique au bas de l'écran:
                Il est donc possible d'utiliser la partie supérieure pour afficher une animation...
                alt text
                alt text
                Ma question est donc: Serait-ce envisageable ou non ?
                Perso j'adorerai l'idée.
                Marcelo Tavares 1 Reply Last reply Reply Quote 0
                • Marcelo Tavares
                  Marcelo Tavares @Starcom last edited by
                  If you are looking for quality and unique Marquees, I have a project that might interest you!
                  https://github.com/marcelosofth/marquee
                  Starcom 1 Reply Last reply Reply Quote 0
                  • ashleyackley
                    ashleyackley last edited by
                    @poppadum I am digging into Dynquee for the first time in a couple years to make a base image and a video about it. I wanted to ask directly if there is any weirdness with Using a pi5, and if the GitHub will be updated to reflect any new info. I clicked your discord link but it just brought me to the app without any user, so I will have to ask here.
                    • Starcom
                      Starcom @Marcelo Tavares last edited by
                      @Marcelo-Tavares Thank you very much but what I need is a display system, not the png of marquees.
                      100.8k
