    Rotate output on official 7 raspberry display
    rotate output official display
    3197
    • mtd
      mtd last edited by
      Hello to all,
      i have a rpi 3B+ with an official raspberry 7" Touchscreen (V1.1) attached to it.
      i installed the most recent recalbox 8.1 on it and after adding "dtoverlay=vc4-kms-dsi-7inch" to the recalbox-user-config.txt ecerything works fine, except that the video output is upside down. I tried to add the following parameters to the config without success:
      lcd_rotate=2
      display_rotate=2
      display_lcd_rotate=2
      dtoverlay=vc4-kms-dsi-7inch,invertx=1,inverty=1
      dtoverlay=vc4-kms-dsi-7inch,invertx=true,inverty=true
      dtoverlay=vc4-kms-dsi-7inch,invertx,inverty
      I already searched the web but cant get my problem solved.
      fun fact: when i attach an older rpi2 with a clean install of the most recent recalbox os for rpi2 (i think 8.0) to the display, it works out of the box without adding vc4-kms-dsi-7inch to the config.txt and display_rotate=2 works great.
      Any help on this one is appreciated.
      thx in advance.
      • Alvin
        Alvin Banned @mtd last edited by Alvin
        @mtd said in Rotate output on official 7 raspberry display:
        Just rotate the whole Pi 180 degrees !
        • mtd
          mtd last edited by
          thought about that, but unfortunately the cables for the monitor interface are to short to turn the mainboard of the Monitor.
          • mtd
            mtd last edited by
            i could resolve the Problem by adding the following to /boot/cmdline.txt "video=DSI-1:800x480@60,rotate=180". just appended it to the end of the line.
            works only in combination with "dtoverlay=vc4-kms-dsi-7inch" in the config.txt
            mtd 1 Reply Last reply Reply Quote 0
            • mtd
              mtd @mtd last edited by mtd
              @mtd
              the parameters in the cmdline.txt work fine for the recalbox menu and games. KODI is still upside down.
              i think its simpler to just get another case where the display ist turned physically as @Alvin implied.
              davidb2111 1 Reply Last reply Reply Quote 0
              • davidb2111
                davidb2111 Staff @mtd last edited by
                Hello @mtd
                Yep, one needs to modify its /boot/recalbox-user-config.txt by adding:
                and /boot/cmdline.txt with:
                at the end of the existing line.
                I think I will create a new "case" to automate those 2 settings.
