    PSX - Enhanced resolution in RPI3/4
    enhanced rpi34
    2062
    • dantezote
      dantezote last edited by
      Hello everybody!
      I have a rpi3 model B, which I use a lot with recalbox.
      Lately I'm playing mostly with PSX, and I always try to do it with the "Enhaced resolution(slow)" option, but many titles (e.g. tomb raider) slow down enough that I can't play them that way, even with speed hack enabled (with which I don't notice any change).
      I was wondering if a rpi4 is powerful enough to run psx better with this option enabled, could someone with one confirm this please?
      Thank you very much!
      • Pitch64
        Pitch64 Staff last edited by
        Hello, this option is not on rpi4 as this is a 64 bits system 🙂
        Next release? Soonâ„¢
        • RustyMG
          RustyMG last edited by
          @dantezote @Pitch64 Hi both. On my Pi4 setup I almost always had enhanced resolution on, or render at x2 resolution - cant remember the specific wording, and with approx 150 PS1 games, very few suffered any slowdown. Not sure if Pitch64 is saying that option is no longer avail in (the 64 bit) Pi4 8.1 release? Not sure why that would be the case to be honest.
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
          Zing dantezote 2 Replies Last reply Reply Quote 1
            Zing Global moderator Translator @RustyMG last edited by
            @rustymg I quoted this in another thread: "Enhanced Resolution" removed from Pcsx-Rearmed on Recalbox 8.1?:
            PCSX-ReArmed is optimized specifically for 32-bit ARM devices, and "enhanced resolution" option dependent on dynarec support, which is only available on 32-bit ARM, and Recalbox 8.1 is 64bit.
            If you are using the "Enhanced resolution" option, you are not using Recalbox version 8.1.
            Or, you are using Recalbox version 8.1, so you are using another option than rendering at x2 resolution, but the "Enhanced resolution" option is not available in 64bit (and Recalbox 8.1 is 64bit).
            • dantezote
              dantezote @RustyMG last edited by
              Thank you all very much.
              @rustymg said in PSX - Enhanced resolution in RPI3/4:
              Thanks Rusty! Could you confirm which version of recalbox you use and if it is the same method to increase the resolution?
              RustyMG 1 Reply Last reply Reply Quote 0
              • RustyMG
                RustyMG @dantezote last edited by
                @dantezote it was 8.01 on a Pi4. I cant remember the exact option as Ive recently moved house and the Pi4 is still in a box somewhere.
                Just read the link Zing mentioned - that is just crazy that 8.1 is worse for PSX emu than 8.01 (due to the emu - not Recalbox). I will need to tell my mates not to upgrade, as they mostly play PSX & Dreamcast games on their setup.
