    Recalbox 8.0.2 - Argon One case script - cooler not working
    recalbox 8.0.2 argon case script cooler
    • wlcina
      wlcina last edited by
      Hello all,
      I installed recalbox few days ago, and tried PSP game Ridge racer.
      Everything was great for a while and then it start stuttering.
      I found that the cpu was very hot, and I bought argon one case.
      Unfortunately I am not able to get the cooler (ventilator) to be enabled.
      I got always this error:
      # Traceback (most recent call last):
        File "/recalbox/scripts/argonone/argononed.py", line 9, in <module>
          bus = smbus.SMBus(1)
      FileNotFoundError: [Errno 2] No such file or directory
      I tried reboot, then setup argonone-config to put cooler always on, but still, it just does not work. The same error appears.
      Select fan mode:
        1. Always on
        2. Adjust to temperatures (55C, 60C, and 65C)
        3. Customize behavior
        4. Cancel
      NOTE: You can also edit /recalbox/share/system/argononed.conf directly
      Enter Number (1-4):1
      Restarting script /recalbox/scripts/argonone/argononed.py ...
      Script /recalbox/scripts/argonone/argononed.py not running
      Starting script /recalbox/scripts/argonone/argononed.py ...
      /etc/init.d/S99argononed [RESTARTED]
      Fan always on.
      Despite I tried to search on forum, I did not find help. Most links are to "https://www.argon40.com/learn/index.php/2020/03/10/argon-one-installation-guide-for-recalbox/" which does not exists anymore - "404" error.
      Can someone help me?
        Zing Global moderator Translator @wlcina last edited by
        @wlcina
        • https://forum.recalbox.com/topic/25352/recalbox-8-0-beta/3?_=1652750452871
