    Cannot connect to Wifi
    cannot connect wifi
    • mikeyramone1234
      mikeyramone1234 last edited by
      Very new user here. I just figured out how to open recalbox manager on my phone.
      My recalbox connected to the internet the day I got it as far as I know. I am trying to connect now so I can enter the script for the safe shut down feature on the Retroflag NesPi + case I just installed. Under network settings my status says "not connected", however there is an IP address available and I am able to connect to my recalbox via my smartphone when I type the IP address into the search bar. Any help would be appreciated.
        Zing Global moderator Translator @mikeyramone1234 last edited by
        @mikeyramone1234 If the internet is working, ignore the "not connected" status.
        If it doesn't work, give more information:
        • What is your version of Recalbox (say the version, don't say "latest")?
        • Did you build your Recalbox yourself, or download a ready-made image from the internet, or did you buy everything ready-made?
        • What is your hardware (PC/Rpi0,1,2,3,4)?
        • Have you tried reconnecting the internet through the WPS option?
