    unable to reset hotkeys recalbox 8.0.2
    unable reset hotkeys recalbox 8.0.2
    • Casual_bean
      Casual_bean last edited by
      I just moved from batocera to recalbox, and I wanted to disable the shader hotkeys via the retroarchcustom.cfg file. However, every time I make the shader hotkeys "nul", and then play a game, the config resets back to normal. Is there a way to permanently change the hotkeys?
      ChrisK bss_ 2 Replies Last reply Reply Quote 0
      • RustyMG
        RustyMG last edited by
        Um, shaders are disabled by default in the settings Im sure?
        You mean so if your playing a game, you cant accidentally hit some wild key combo on your joypad that enables or cycles thru them? 🤔
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        • ChrisK
          ChrisK @Casual_bean last edited by
          @casual_bean I've got the same problem; I would like to change/override some of the default hotkey settings but the defaults keep getting restored. Let's hope they resolve this problem.
          • bss_
            bss_ @Casual_bean last edited by
            @casual_bean Same thing happened with me. I am also looing for permanently change the hotkeys.
