    Unsolved MAME appears to be broken in Recalbox 8.
    Emulator Arcade/PC/Console
    mame appears broken recalbox
    10
    26
    10580
    • RustyMG
      RustyMG last edited by RustyMG
      Hi all, thought I was going crazy so did some checking today to ensure I was correct.
      I setup a clean 7.22 install on my Pi4 on a spare 32gb microSD, and have every single bios file for every emulator.
      I then copied over all my MAME games and folders, and tried my 66 working light gun games in MAME (I have them in their own dedicated sub folder).
      Every single game worked, with some obviously requiring me to go into settings and ensure the 2010 or 2015 emulator is their default when running (eg Area 51, Point Blank).
      I then did an online update to 8.02, and now of those 66, 43 do not now work. Literally, only a third of the games now work when all I have done, is update to Recalbox 8.
      The games still attempt to use the cores as defined under 7.22, so it looks like the only way to use MAME is to re install the old version.
      And its not obscure games that arent working - its games including Area 51, Point Blank, Point Blank 2, Lethal Enforcer etc.
      Can anyone confirm what has happened ?
      Many thanks.
      Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
      rollbrett lexx0006 2 Replies Last reply Reply Quote 0
      • rollbrett
        rollbrett @RustyMG last edited by
        @rustymg iam not familiar with mame, but in the documentation is the standard mame Core the LIBRETRO-MAME 2003-Plus and your Romset should match with one of these ROMSET MAME 0.78-0.188
        Have you create for the MAME2010 and 2015 Roms subfolders?
        https://wiki.recalbox.com/en/emulators/arcade/mame/libretro-mame-2015
        ┣ šŸ“ recalbox
        ā”ƒ ┣ šŸ“ share
        ā”ƒ ā”ƒ ┣ šŸ“ roms
        ā”ƒ ā”ƒ ā”ƒ ┣ šŸ“ mame
        ā”ƒ ā”ƒ ā”ƒ ā”ƒ ┣ šŸ“ Mame 2015
        ā”ƒ ā”ƒ ā”ƒ ā”ƒ ā”ƒ ┣ šŸ—’ game.zip
        ā”ƒ ā”ƒ ā”ƒ ā”ƒ ā”ƒ ┣ šŸ“ game
        ā”ƒ ā”ƒ ā”ƒ ā”ƒ ā”ƒ ā”ƒ ┣ šŸ—’ game.chd
        SUPERPi CASE-J (new) RPi 3b+ Recalbox
        MEGAPi CASE RPi 3b Blast16
        NESPi 4 CASE RPi 4 Recalbox
        GPi CASE RPi Zero 2 W Recalbox
        My RetroArchivments
        cesartaqui 1 Reply Last reply Reply Quote 0
        • RustyMG
          @rollbrett Hi, as mentioned, everything worked perfectly in 7.22 (and in Recalbox 6 as well) - everything.
          It was only when I went to Recalbox 8, the working games suddenly stopped working.
          Also, that documentation isnt correct for the Pi. You simply highlight your game, press "hotkey" and A, and change the default emulator for the game from the default (2003plus) to the required core, eg 2010 or 2015, and that change is saved out in the gamelist.xml file.
          Definitely looks like MAME is broken in Recalbox 8 unless something radical has changed that Im not aware of with MAME.
          • cesartaqui
            cesartaqui @rollbrett last edited by
            This post is deleted!
            • Lucatort
              Lucatort last edited by
              Same problem!!
              Not working a lot of lightgun games that have worked until update.allnroms verified and fitting on mame version
              I. E. Nycaptor, lethal justice, crossbow, chiller, Cheyenne, under fire and so on. about 80%.
              Only still working are jurassic Park and alien gun
              RustyMG 1 Reply Last reply Reply Quote 0
              • RustyMG
                RustyMG @Lucatort last edited by RustyMG
                @lucatort I had a reply on Discord.
                Poster said that most lighgun games dont work if you have the Dolphin bar plugged in, in the same way the PS1 light gun games in 7.22 didnt work if you had the Dolphin bar plugged in.
                Im going to unplug it today and try the same games.
                IF they work, looks like MAME will need fixed in the next release.
                Lucatort 1 Reply Last reply Reply Quote 1
                • Lucatort
                  Lucatort @RustyMG last edited by
                  @rustymg
                  thank you very much for the update. I don't know if I understand correctly: so if I start the roms without dolphin bar and then, after the start ,I connect it, the roms work? and can I use the lightgun?
                  to think that I was behind it for days!
                  • RustyMG
                    @lucatort No, apparently the only way to play those games is with a joypad - FAR from ideal, as I only bought the Dolphin to play Point Blank and Lethal Enforcers - both of which now do not work with it!
                    BUT, I have still to test the theory, and will unplug the bar and try the games as soon as possible.
                    Lucatort 2 Replies Last reply Reply Quote 0
                    • Lucatort
                      @rustymg if it's could help you, please consider that point blank (my favorites one) game series and lethal enforce are well emulated and playable on psx emulator of recalbox. Consider also Naomi games are very pretty. I'd like to continue run mame for older games like exidy ones (crossbow, Cheyenne etc). If it will start to works again I complete my working collection of lightgun with more than 100 roms.
                      Stay well and thanks
                      • Lucatort
                        @rustymg it works if you disconnect and riconnect the bar after launching rom!!!
                        I spent two weeks....
                        • RustyMG
                          @lucatort you have 100 working light gun games?
                          I thought I was doing well getting 66 to work!
                          That on a Pi or a PC though?
                          If on a Pi, is there any easy way you can list them for me?
                          Lucatort 1 Reply Last reply Reply Quote 0
                          • Lucatort
                            @rustymg rpi 4
                            With exception of saturn. They are more or less ones indicated in wiki recalbox https://wiki.recalbox.com/en/basic-usage/features/lightgun-on-recalbox/games-compatibility-list
                            So you should consider emulate snes, dreamcast, nes, ps1, Naomi, megadrive, 3do ( not perfect), sega cd etc.
                            My failure and pain are carnevil, virtua cop2/3
                            • RustyMG
                              @lucatort Ah, I was meaning MAME only games. I have lots of others, as my install is 460 ish gig and has over 10,000 games. Yes, I cant get those ones to work either, even with the additional chd file for Carnevil.
                              Lucatort 3 Replies Last reply Reply Quote 0
                              • Lucatort
                                @rustymg how? I mean carnevil and virtua cop I. E.
                                Thanks
                                • Lucatort
                                  @rustymg now recalbox seems to be crashed!
                                  No rom starts nes nor snes no mama. Same things happened only to me?
                                  • RustyMG
                                    I notice no devs have commented.
                                    I got told on Discord that MAME is indeed broken in Recalbox 8, and the only way for most of the light gun games to work is unplug the Dolphin bar, load the game and then plug it back in.
                                    Far from ideal.
                                    I have still to try this to confirm admittedly.
                                    • RustyMG
                                      RustyMG @RustyMG last edited by Pitch64
                                      @Bkg2k @pitch64 Well, tried disconnecting my Dolphin bar, and every single one of the 40ish MAME light gun games that didnt work all worked fine with it unplugged.
                                      Im guessing that whatever went wrong with the PS1 light gun games in Recalbox 7 has unfortunately happened with MAME in 8.x, ie Point Blank and all the other PS1 light gun games wouldnt load if the Dolphin bar was plugged in.
                                      Bkg2k and Pit64, Ive included you guys in this post in case you are unaware of this issue. šŸ‘
                                      • neo207
                                        neo207 last edited by
                                        why did i update? fb-neo games (street fighter 3, ...) crash occasionally, or don't boot (black screen, have to pull the plug)...
                                        everything worked perfectly before.
                                        can someone help? if the solution is to install everything from scratch i will never ever update anything again!
                                        • Lucatort
                                          @rustymg sorry I need your help.
                                          How I can get carnevil works on rpi4 without lags?
                                          Which kind of setup core I've to use with mame 2003 plus?
                                          Some question for virtua cop
                                          Thanks
                                          • RustyMG
                                            @lucatort Hi,
                                            Both games are unplayable on the Pi versions of Recalbox
                                            Copyright Ā© 2021 recalbox.com
