    After RECALBOX Update to 8.0.1, Kodi Does not start anymore
    MediaCenter & Dualboot
    recalbox update 8.0.1 kodi does start anymore
    1921
    • NoGameForOldMan
      NoGameForOldMan last edited by
      Dears, after the recent update to 8.0.1 the Kodi start not anymore.
      Any idea?
      enclosed my scrip:
      https://transfer.sh/NpR1E2/recalbox-support-d8a44f28-a47f-11f7-a5f1-663f669a1b74.tar.gz
      Thank you in advance, best regards!
      NoGameForOldMan 1 Reply Last reply Reply Quote 0
      • NoGameForOldMan
        NoGameForOldMan @NoGameForOldMan last edited by
        short update, also with Version 8.0.2 Kodi does not start.
        regards!
        • NoGameForOldMan
          hello, anyone an idea? thanks
            Zing Global moderator Translator @NoGameForOldMan last edited by
            @nogameforoldman It's a known bug:
            https://wiki.recalbox.com/en/recalbox-8-0-faq#rpi4
            • NoGameForOldMan
              NoGameForOldMan @Zing last edited by
              @zing first go all thank you for your support. I thought in the first instance that this might help, since the "cmdline.txt" file was incomplete. but after changing the file, the failure is still present, means KODI still does not function, once I try to start KODI it immediately kicks me back to the home screen. any further idea for me?
              thank you.
              nicolas-bourdon 1 Reply Last reply Reply Quote 1
              • nicolas-bourdon
                nicolas-bourdon @NoGameForOldMan last edited by
                @nogameforoldman I have the same problem 😞
                srvduplex 1 Reply Last reply Reply Quote 0
                • srvduplex
                  srvduplex @nicolas-bourdon last edited by
                  @nicolas-bourdon
                  Hi there
                  What was the solution?
                  I got the s as me… exactly the same ! 😤
                  Thank you for you feedback
                  Srv
