    Can't switch to another Playstation Emulator
    Emulator Arcade/PC/Console
    cant switch another playstation
    • BitFunX
      BitFunX Banned last edited by
      In Recalbox 8 I'm using the Playstation 1 "Duckstation"-Emulator on my Asus Eee PC.
      Now I want to change to another Emulator (Libretro Mednafen_PSX_HW, Libretro PCSX-Rearmed, Libretro Mednafen_PSX or Libretro Swanstation) but this doesn't work !
      I go to
      Settings -> Advanced Settings -> Advanced Emulator Configuration -> Sony Playstation 1
      and change the Emulator to one of the ones mentioned above.
      Then I got back and when I start a Playstation game, always the "Duckstation"-Emulator and not the one that I had chosen starts.
      So why can I switch to another Playstation Emulator ?
        Zing Global moderator Translator @BitFunX last edited by
        @bitfunx The advanced setting is for all games... that don't have a particularly defined emulator. A specific configuration overrides a generic configuration.
        From what I'm seeing in your other thread, you must have set in game settings to start with a certain emulator, so it's not working. Or, you may have a problem with the gamelist.
        • Darkneo
          Darkneo last edited by
          Hi there,
          I am facing the same issue! I was previously on PSX_rearmed and wanted to give a try with "Duckstation", to see if it fixes issues I am having with PSX games. My controlers were not recognized at all (even joypad).
          After rebooting, I reverted back to PSX_Rearmed, but DuckStation is still starting....
          Darkneo 1 Reply Last reply Reply Quote 0
          • Darkneo
            Darkneo @Darkneo last edited by
            FYI, I finally found a way to change it back to PCSX_Rearmed:
            • Change the emulator in advanced settings,
            • reboot the system
            • check back in the advanced settings the emulator is fine
            If you start a game immediately after changing the emulator (without rebooting the system), it does not seem to be taken into account (and no info is displayed to ask a reboot). If it might help 🙂
