    List of basic controls?
    list basic controls
    • darknesscrysis
      darknesscrysis last edited by darknesscrysis
      I'm on Android and can't see the documentation. Give me a list of the basic controls please. I don't understand why the controls don't pop up when you keep the hotkey pressed or something like that. I've had to press every button to exit a game and for some reason I kept making screenshots. Will I need a post-it in the middle of the screen while I play?
      Zing darknesscrysis 3 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @darknesscrysis last edited by
        @darknesscrysis
        https://wiki.recalbox.com/en/basic-usage/getting-started/special-commands
        • darknesscrysis
          darknesscrysis @darknesscrysis last edited by darknesscrysis
          I'll copy it here now that I'm on the computer. When I'm using recalbox I can't access the wiki from android but I can access the forum. I just need a way to take a look at the controls from the phone, although it would be simpler if I could look them from recalbox.
          Special In-Game Commands:
          In Recalbox, the shortcuts are, for the most part, a combination of keys involving a key named HOTKEY (HK) which must first be defined in the controller's settings options.
          The names used for the buttons are those of the Super Nintendo controller (the L1, R1, L2, R2, L3 and R3 buttons are based on the PlayStation controller).
          See this page for details.
          Basic commands
          Back to Gamelist
          Exit the current game to return to the game list:
          HK + START
          Add credits [Insert Coin].
          Add credit for arcade and NeoGeo games:
          SELECT
          Restart the game [Reset]
          Restart the current game:
          HK + A
          Rewind [Rewind]
          Rewind the game:
          HK + LEFT
          Fast Forward
          Fast forward the game:
          HK + RIGHT
          Save
          Save [Save State]
          Create a save point in the current location:
          HK + Y
          Load a backup [Load State]
          Load the last backup point in the current location:
          HK + X
          Change the backup slot [Select Slot].
          Select a backup slot from the 10 available slots (per set, numbered 0 to 9):
          HK + UP or DOWN
          Change CD
          Eject CD [Disk Eject]
          Allows you to simulate the ejection or insertion of a CD into the console (a function intended for games consisting of several CDs or disks):
          HK + L. STICK to the UP.
          Change CDs [Disk Swap]
          To be able to swap disks, all the images in your game must be in a .M3U file.
          Selects the previous or next disc (a function for games consisting of multiple CDs or disks):
          HK + L. STICK to the LEFT or to the RIGHT
          To summarize simply how to change CDs in 3 steps:
              I press Eject and the drawer opens:
              I change CDs (-1, -2, ... or +1, +2, ...):
              HK + L. STICK to the LEFT or to the RIGHT.
              I press Eject, the drawer closes and I continue the game:
          Display
          Screenshots [Screenshot]
          Take a screenshot of the current screen (.png file saved in the screenshots folder):
          HK + L1
          Recording video [Recording]
          Record a video sequence (file saved in the screenshots folder):
          Press HK + R3 (Press R. Stick)
          The 1st press starts the recording and the 2nd stops the recording.
          Change the shader [Shaders Swap]
          Change the video filter (shader) displayed on the screen:
          HK + L2 or R2
          Translate [Translate]
          Translate "on the fly" and overlay the text displayed on the screen:
          HK + L. STICK to the DOWN
          Requires an Internet connection to operate. More information on Retroarch AI (In-game translation)
          Display FPS [FPS Display]
          Display the number of frames per second (FPS) currently being rendered:
          HK + R. STICK to the DOWN
          Advanced user
          Access the RetroArch menu [RetroArch Menu].
          Access the RetroArch menu:
          HK + B
          In the Menu:
          When you are int he menu, there is some special commands available.
          Search function
          From the systems menu activate the search function.
          R1
          Shutdown menu
          From the systems menu, brings up the Recalbox shutdown menu.
          Select
          Start game clips
          If you select to use game clips as screensaver, you can start them without to wait the defined time.
          Y
          • Pitch64
            Pitch64 Staff last edited by
            There is a PDF file given in the wiki, faster than copypastaing it here
            Next release? Soon™
              @darknesscrysis
              This is not necessary, but if you want something like that, you can create an overlay, a user did this with the MK and MK II moves, and it looks cool, see:
              https://forum.recalbox.com/topic/25752/bezels-overlays-mk-mk2
