    Recalbox 8.0 Games Settings
    recalbox 8.0 settings
    1889
    • extracoconut
      extracoconut last edited by
      Hi
      New to Recalbox. Using 8.0.
      Main question relates to Games Settings menu, mainly Game Ratio and Recalbox Overlays... They do nothing for me. If I change select "Core Provided" say, for all RetroArch emulators, it doesn't make RetroArch use Core Provided. Same for ratio. It makes no difference what options I select in Games Settings.
      Is this normal?
      Second question... will there be an option to hide systems in a future update? I'd rather not have to go in and out of the folder structure to change "ignore" setting or the name of a system folder to something that hides it, each time...
      Oh, and there's a third, sorry. Can I change the boot video & loading screens?
      Ta
        Zing Global moderator Translator @extracoconut last edited by
        @extracoconut
        https://wiki.recalbox.com/en/tutorials/video/display-configuration/complete-video-configuration-guide
        https://forum.recalbox.com/topic/25259/hide-consoles/7
        https://wiki.recalbox.com/en/basic-usage/features/boot-videos
        extracoconut 1 Reply Last reply Reply Quote 0
        • extracoconut
          extracoconut @Zing last edited by
          @zing Thanks for the info on the third question. That helps.
          Not sure about the other two answers though. You've basically repeated what I was saying the second...and for the first, I don't know, maybe there is something I am missing, but I'm talking about scaling...via the Games Setting option, the one you get from pressing the START button in the frontend.
            @extracoconut So, see if this helps:
            https://wiki.recalbox.com/en/advanced-usage/configuration-override
            extracoconut 1 Reply Last reply Reply Quote 1
            • extracoconut
              @zing Ah. Does this mean then that if I already have an override for EVERY game and they reside in the game folder, then the Recalbox overrides, which sits in EmuStation, won't do anything...because when the game starts it will take the override from the game folder and not EmuStation / Recalbox?
              • Pitch64
                Pitch64 Staff last edited by
                Overrides have full priority over others way to use the same options.
                Next release? Soon™
