    Recalbox 8.0 HDMI-->DVI black screen
    recalbox 8.0 hdmi--dvi blank
    • abocaman
      abocaman last edited by abocaman
      Well, I tried to find any solution searching in the web and forum, nothing worked for me.
      I had Recalbox runing 7.2 working properly with rotating the screen 180 degrees and HDMI-->DVI ouput working well. After the upgrade to 8.0 black screen and no more. The system finally start and I can connect via ssh.
      I tested with the same sdcard and debian and works properly.
      I tested a fresh install of RB 8.0 the same, black screen and nothing more.
      I tried to comment the line of the splash rainbow and It doesn't show it.
      #disable boot rainbow
      #disable_splash=1
      All is running in a Raspberry Pi 3B+
      Any Ideas?
      Zing davidb2111 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @abocaman last edited by
        @abocaman See if this helps:
        • https://wiki.recalbox.com/en/tutorials/video/display-configuration/complete-video-configuration-guide
        • https://wiki.recalbox.com/en/tutorials/system/modification/configtxt-configuration
        • davidb2111
          davidb2111 Staff @abocaman last edited by
          Hi @abocaman
          Could you try this by connecting ssh and executing those comands:
          mount -o remount,rw /boot
          echo -n " video=HDMI-A-1:1280x720M@60" >>/boot/cmdline.txt
          reboot
          • simpleman
            simpleman last edited by
            @abocaman only registered here so i can share it with the world lol i had the same problem i fixed it with this line:
            #global.videomode=auto
