    Recalbox 8.0 and GPi Case: Constantly Freezing cause of battery use?
    recalbox 8.0 gpi case constantly freezing cause battery
    • heinzgruber
      heinzgruber last edited by
      hi,
      i'm using a GPi Case with Recalbox 8.0. The system freezes very often on the startup screen and seems to stuck in a boot loop with grapical distortions etc. Already installed Recalbox multiple times on different SD cards.
      I saw here and on Reddit other with the same problems. It seems the problems occurs only in battery mode. I'm using rechargeable Eneloop (black ones) and non rechargeable ones. Is it possible that Recalbox in interaction with GPi Case has problems with battery mode?
      Thanks
        Zing Global moderator Translator @heinzgruber last edited by
        @heinzgruber See if this helps:
        https://forum.recalbox.com/topic/25374/visual-glitch-on-pi-zero-2-with-gpi-case/8
        junkotovar 1 Reply Last reply Reply Quote 0
        • junkotovar
          junkotovar Banned @Zing last edited by junkotovar
          This post is deleted!
          • Asdert
            Asdert last edited by Zing
            Hi, I have a similar issue with GPi case 1, Raspberry zero 2, and recalbox 8.0. I tried with the image of another system, with the same batteries and SD it correctly boots. However when using recalbox 8.0, I can not start with batteries only. I have to boot with a power cable, and when it is fully loaded I can remove it and continue playing with batteries only.
            When booting from batteries it continues to stop and reboot at the "Have fun" screen. I tried both with the secure shutdown switch on and off.
            LINK REMOVED BY MODERATION.
            101.4k
