    8.0 Beta controller issues/dreamcast does not use joystick
    8.0 beta issuesdreamcast does joystick
    • Paulska
      Paulska last edited by
      Im not sure where to post bugs ive found in the beta version.
      sometimes when unplugging a controller and plugging it back, it doesn't work.
      Once this happens, any new controller plugged in will not work and you have to restart.
      This issue also persists sometimes when the bluetooth controller gets disconnected for a second.
      second issue.
      Dreamcast no longer runs off the joystick, you have to use the D-pad. playing marvel vs capcom is unbearable for my kids.
      I did an update from 7.2.2 to 8.0 beta
      • Pitch64
        Pitch64 Staff last edited by
        This could come from a RetroArch change. They changed how to select the joystick/dpad following the original hardware.
        In RetroArch options, go to Input > Input User 1 Binds > User 1 Analog To Digital Type and play with this option.
        Next release? Soon™
