    Recalbox 7.2.2 and 8BitDo M30
    GamePad/GPIO/USB encoder
    recalbox 7.2.2 8bitdo m30
    1737
    • Svetlyachok
      Svetlyachok last edited by
      This gamepad has 3 global modes (Android, Windows, MacOS) If i connect it to RB 7.2.2 like "Android" it works in main dashboard and in Kodi menu but "dead" in game mode in all emulators.. "MacOs" mode doesnt recognize of this version recalbox. And mode "Windows" is OK only if you activate GPIO-controller in "WebFace" but very long time starting game. Previously on version 6.0 of recalbox is OK in everything mode.. Even if i install 6.0 version and upgrade it to 7.2.2 from menu (Not clean install 7.2.2) M30 still works in "Android" mode.. Something "new" broke old stabile..
      Sorry for my english, i hope are everyone understand me.. 🙂
        Zing Global moderator Translator @Svetlyachok last edited by
        @svetlyachok
        It is not possible to upgrade from version 6.0 to 7.2.2 via the menu, you are certainly not able to do that, some of your information is wrong.
        Do a clean install, from scratch, of the latest official version, don't copy the configuration files or you will have a lot of bugs, watch this video and you will understand how to do it (turn on the subtitles):
        https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=31&ab_channel=Recalbox
        Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
        Svetlyachok 1 Reply Last reply Reply Quote 0
        • Svetlyachok
          Svetlyachok @Zing last edited by
          @zing Of course .. sorry ... my mistake ... 7.0 version ...
          • Svetlyachok
            Some new..
            7.2.2 and 8BitDo M30, after start any game i have "dead" gamepad, but if i reconnect it to Recalbox, and no exit of game - all functions is works! But if i enter to nestopia (special key and B button), i have doesnt work gamepad again ...
            How to fix it? Anybody knows?
            • Svetlyachok
              Svetlyachok last edited by Svetlyachok
              Soo..
              I test for this bug all versions of 7 release..
              "Good" work only one 7.0.1. After start game any buttons doesent work, but if i reconnect gamepad without exit game, all buttons is OK even if enter retroarch.. Next game - same trouble..
              I'l test it bug on
              7.0
              7.0.1
              7.1
              7.1.1
              and all of 7.2 versions
              (I use it on Rpi3b+)
                @svetlyachok See if there's anything in the documentation that might help:
                • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuration-test/test-your-joystick-with-sdl2-jstest
                • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuration-test/manually-connect-a-bluetooth-control
                • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/how-to-customize-controller-mapping
                • Svetlyachok
                  Svetlyachok @Zing last edited by Svetlyachok
                  @zing I dont think so .. This game pad works normaly in game after reconnect (hold start button is off goy and then on again) after that in this game is OK!!
                  Today i test it like second gamepad, first gamepad was "Wingman USB gamepad" soo, like second gamepad its OK from start, and dont need reconnect it ...
                  • Svetlyachok
                    Clean install 8.0 version is solve this problem ! Update from 7.** not ...
                    Everyone if you have some problem with some gamepad - try to recalbox 8 version ..
