    Boot video not working
    splash bootvideo boot
    8
    8
    2500
    • LuckyDucky
      LuckyDucky last edited by
      I put a 720p, 14 second long boot, mp4 file into \recalbox\share\bootvideos and it just shows a default recalbox boot video. I have no idea why it's doing this, if anyone can help that would be great.
      RustyMG davidb2111 2 Replies Last reply Reply Quote 0
      • RustyMG
        RustyMG @LuckyDucky last edited by RustyMG
        @luckyducky yep, I asked about this months ago and got no answer.
        There is a bug in Recalbox, BUT, its simple to work around.
        Firstly, you obviously need to edit the recalbox.config file in recalbox\system
        Change line 36 ish to: system.splash.select=custom
        And, save the changes.
        Now, boot up Recalbox, and whilst its running, log into your Pi remotely via WinSCP, and copy your video files to the recalbox\bootvideos folder, then shut down Recalbox.
        When you reboot, your videos will play 👍
        I'm not sure if I can post links, so, if you go onto Youtube and search for "AD&MEDIA" [ without spaces - this site is inserting spaces] you will see that these guys do some fantastic Recalbox boot videos. I've put about 7 or 8 of theirs on my usb stick
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        • davidb2111
          davidb2111 Staff @LuckyDucky last edited by
          @luckyducky
          Did you modify your recalbox.conf ? You should set system.splash.select to custom.
          David
          RustyMG 1 Reply Last reply Reply Quote 0
          • RustyMG
            RustyMG @davidb2111 last edited by RustyMG
            @davidb2111 um, isnt that what I said 2 days ago?
            Also, that alone doesn't work due to the bug.
            As I mentioned, you also need to copy the files over whilst Recalbox is running or they won't play.
            Im sure I read this was on the "to do" list of fixes.
            davidb2111 1 Reply Last reply Reply Quote 0
            • davidb2111
              davidb2111 Staff @RustyMG last edited by
              @rustymg said in Boot video not working:
              Sure, I've just tested on the last internal beta and it works.
              • RustyMG
                @davidb2111 Excellent stuff 👍
                • Kathryn
                  Kathryn last edited by
                  If your boot video isn't working, it may be due to incompatible file formats, corrupted files, or incorrect BIOS settings. Ensure the video is in a supported format, check your BIOS settings to enable boot videos, and verify that the video file is not corrupted. Updating your graphics drivers and BIOS firmware can also help resolve compatibility issues.
                  • Charlotte
                    Charlotte last edited by Charlotte
                    This post is deleted!
