    n64 RE2 problem on Rp4
    Emulator Arcade/PC/Console
    re2 rp4
    2307
    • IGA
      IGA last edited by
      Hello!
      I've use recalboxon for raspberry pi 4.
      And could somebody tell me what need to correct run RE2 n64? ( dont find it in search)
      If i run it through muppen64 next - i've got only backgrounds in game and lost all 3d models.
      If run through muppen64 - i' ve got on the contrary lost backgrounds an only models on the black screen
      And i can't choose another plugins...
        Zing Global moderator Translator @IGA last edited by
        @iga See if it helps:
        https://forum.recalbox.com/topic/24280/n64-graphics-ok-on-first-start-only
        IGA 1 Reply Last reply Reply Quote 0
        • IGA
          IGA @Zing last edited by IGA
          @zing sorry, but i don't understood about
          Is this game not emulated as well it all or just what?
            @iga If you are using the latest official version of Recalbox the game should be emulated acceptably, or there is some conflicting manipulation that will likely resolve itself by resetting to factory settings.
            If you are not using the latest official version of Recalbox, please use it.
            Note: There are not only 2 emulators available for the N64 on RPI4:
            https://recalbox.gitbook.io/documentation/hardware-compatibility/emulators-compatibility
            • IGA
              @zing whar yiu mean "emulated acceptably" ?
              At Libretro - Mupen64Plus_Next or Mupen64Plus or Mupen64Plus - RICE - all 3d models are missing. At the Libretro - ParaLLEl N64 the game is stuck
                @IGA
                what you mean "emulated acceptably" ?
                By "emulated acceptably" I mean: The game should be playable, even if it's not at full speed (I don't know how this game performs in terms of speed, so I can't say if the game runs perfectly so I say at least should run "acceptably")
                Note that previously you had only given information about 2 emulators, and now about 4, you need to be as accurate as possible and give as much information as possible, I still don't know which version of the system you are using, and I don't know if you've tried the hard reset as I suggested, so I don't know how to help anymore.
                Update to the latest official version, and if you already have the latest official version do a hard reset and try again.
                • IGA
                  IGA last edited by IGA
                  @zing said in n64 RE2 problem on Rp4:
                  Yes, at first i've used 7.1.1 ( where was 3 cores - muppen next, muppen an parralel), now on your advice i've udate to latest 7.2.2 where now 4 cores for n64, but with same effect that was in older version 😞
                  (updated with full format sd card, and after it installed new)
                  And so i've asked about "acceptably".... - we dont have 3d models on any cores - only backgrounds are visible. Did you test it own? Have you same issue at the latest version or what? Or you are and call it playable?)
                    @iga
                    No, unfortunately I can't test it as I don't have an RPi4, I'm just trying to help you, and I'm based on the other comments I see here on the forum, so my initial reference is another post with a similar issue that was resolved in the latest version .
                    Your post is open and anyone can participate, but apparently no one who has an RPi4 has the same problem as you (since no one else has posted anything here).
                    Sorry, I can't help beyond that, so you need to hope that some other user will be willing to test and see if the problem is a bug or if it's a problem specifically with you.
                    IGA Zing 2 Replies Last reply Reply Quote 0
                    • IGA
                      @zing everything is clear...
                      So, this game can be classified as unplayable because of the problems described above
                      I don't think so...
                        Zing Global moderator Translator @Zing last edited by
                        @zing
                        • Pitch64
                          Pitch64 Staff last edited by
                          You must keep in mind that N64 emulation is really unperfect and some games can have big glitches that we can't fix ourselves but emulators developers could do. 🙂
                          Next release? Soon™
                          • IGA
                            IGA @Pitch64 last edited by
                            @pitch64 said in n64 RE2 problem on Rp4:
                            Wow...🐙
