    Removing roms without deleting
    removing roms deleting
    • marra
      marra last edited by
      Hi, is it possible to remove ROMs from SD back to PC ? I have a pi2 with older OS but want to rebuild onto pi3. No longer have the ROMs on PC. Thanks
      • peterpan123123
        peterpan123123 last edited by
        Open SMB share (\recalbox or similar) of Recalbox on your PC and copy to a local folder. In my example it would be in \recalbox3\User data\roms. Btw. you can even save your saves under \recalbox3\User data\saves. Maybe want to save your bios as well.
          paradadf Staff last edited by
          In Windows you could install a software like this to read your sd card and simply backup anything to your pc. http://www.diskinternals.com/linux-reader/
            wiki link https://github.com/recalbox/recalbox-os/wiki/Acces-in-RO-recalbox-partitions-Windows-(EN)
            • marra
              Thanks for replies. I went on disc internals and installed the free version, works great . I'll look into the other recommendations and get familiarised with them. Thanks again and a thumbs up for disc internals installation.
