    Hide Pre-Installed does not hide Ports
    hide pre-installed does ports
    13
    25
    13539
    • koim
      koim last edited by
      and the 'Ports' folder gets copied again whenever I try to empty or delete it ¯_(ツ)_/¯
      Fourch 1 Reply Last reply Reply Quote 0
      • Pitch64
        Pitch64 Staff last edited by
        You can't delete those ones.
        Next release? Soon™
        • lhari84
          lhari84 last edited by lhari84
          Why not? I have very RAM-intensive theme, every system not shown up makes Emulation Station running smoother, so I‘d really like to remove this one, as I don‘t need it.
          Pi 4:
          Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
          Pi Zero 2W:
          GPi Case 2W, Recalbox 9.0
          • Pitch64
            Developer decision, I'm not one of them.
            Next release? Soon™
            danimourinho 1 Reply Last reply Reply Quote 0
            • the.headz
              the.headz last edited by
              That really should be changed, especially as the games in question (Doom, Wolfenstein) are not suited to young children!
              1 Reply Last reply Reply Quote 3
              • Pitch64
                And if we hide everything and there is no rom on share, EmulationStation will reboot in chain.... It's not made to hide everything.
                Next release? Soon™
                lhari84 1 Reply Last reply Reply Quote 0
                • lhari84
                  lhari84 @Pitch64 last edited by
                  @Pitch64 Why the hide option at all? The way of just deleting not needed games from file system was a fine solution in all previous versions.
                  On the other hand, I‘m sure RB developers are very smart and can handle that (uncommon) situation of no custom roms + hiding included ones 😉
                  Pi 4:
                  Pi Zero 2W:
                    Zing Global moderator Translator @lhari84 last edited by
                    @lhari84
                    You are right about one thing: the developers of the Recalbox team are very smart!
                    But, unfortunately, not everything is as easy as it seems, and among several problems reported, this fact is not something of utmost urgency, so, unfortunately, for now, do not wait for an immediate solution.
                    Thank you for understanding!
                    sergioad 1 Reply Last reply Reply Quote 1
                    • sergioad
                      sergioad @Zing last edited by sergioad
                      @zing then I would prefee Cave story being the non removable, it is not a trunk shareware and it is kid friendly I think that could be the best option
                      • cdtpepette
                        cdtpepette last edited by
                        Hello, you can add emulationstation.collection.ports.hide=1 in recalbox.conf
                        Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
                        Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
                        Pitch64 1 Reply Last reply Reply Quote 1
                        • Pitch64
                          Pitch64 Staff @cdtpepette last edited by
                          @cdtpepette be REALLY CAREFUL with this option. If EmulationStation is crashing, do not complain! 🙂
                          Next release? Soon™
                          cdtpepette 1 Reply Last reply Reply Quote 0
                          • cdtpepette
                            cdtpepette @Pitch64 last edited by
                            @pitch64 Thank for the advice. I 've git my backup, rsync is my friend😀.
                            • Fourch
                              Fourch @koim last edited by
                              @koim I found a way: you have to remove them from the /recalbox/share_init folder, accessible using winscp.
                              Then, you can shut down RB, and delete Ports folder in your USB drive.
                              If it keeps coming back, then instead of removing folders, move subfolders into an "unwanted"-named folder so that the system doesn't keep on copying them back.
                              Pitch64 1 Reply Last reply Reply Quote 0
                              • Pitch64
                                Pitch64 Staff @Fourch last edited by
                                @fourch and on next update, all will be back 🙂
                                Next release? Soon™
                                • danimourinho
                                  danimourinho @Pitch64 last edited by
                                  @pitch64 very poor developer decision. Specially for parents that are making this retroconsoles for young kids. Literally makes no sense
                                  Alvin Scavy Zing 3 Replies Last reply Reply Quote 1
                                  • Alvin
                                    Alvin Banned @danimourinho last edited by
                                    @danimourinho
                                    Yes, it seems so.
                                    In old Versions of Recalbox (I'm still using Recalbox 6 on my Raspberry Pi 3B+) you could simply delete the preinstalled Games and they never showed up again..
                                    Didn't know why they changed that.
                                      Scavy Global moderator @danimourinho last edited by
                                      @danimourinho said in Hide Pre-Installed does not hide Ports:
                                      @alvin said in Hide Pre-Installed does not hide Ports:
                                      @danimourinho
                                      Yes, it seems so.
                                      You can hide all preinstalled games, in fact what is the problem ?
                                      What is the link between parents making retroconsoles for young kids and preinstalled games ?
                                      Alvin Xerobit 2 Replies Last reply Reply Quote 0
                                      • Alvin
                                        Alvin Banned @Scavy last edited by Alvin
                                        @scavy said in Hide Pre-Installed does not hide Ports:
                                        @danimourinho
                                        Yes, it seems so.
                                        So what now ?
                                        Here
                                        https://forum.recalbox.com/topic/26804/hidden-games-reappearing-after-restart/2
                                        you say
                                        "for all preinstalled games, you can hide them using the option in the menu but... if there's no games at all, ES is not working. So devs choose to keep these 3 games to prevent ES crashing."
                                        So it's not possible to hide ALL preinstalled Games.
                                        And for me it's still a stupid decision, because on Recalbox 6 I deleted all preinstalled Games und it was still running even without any Game.
                                        And whats the Problem with someone who wants to build a Recalbox for his Kids ?
                                        Do you want your 4 year old Daughter playing a Game where you're running around shooting Humans, Demons an other Monsters ? (Yes I mean Doom, it's preinstalled and you can't hide it)
                                          Zing Global moderator Translator @danimourinho last edited by
                                          @danimourinho @Alvin
                                          I understand your revolt, but please understand that it is not something as simple as it seems, the development of an operating system goes through several stages in which for an evolution in general, sometimes it is necessary to temporarily give up some resources, and unfortunately it was that's the case.
                                          It's not like the developers wanted this to happen, it's something that they were forced into the development process and had to choose to evolve a lot of features and give that one up, or keep everything as it was just for the sake of it.
                                          You can follow the tips given above and you will get what you want, even if unfortunately not the easiest way.
                                          On Windows XP I was able to move the taskbar to the sides or to the top, and on Windows 11 I can't. I'm sure you don't understand why either.
                                          Microsoft, with a giant team (where everyone gets paid for their work), numerous resources, which sells its operating system, went through this situation that I mentioned before, and decided to launch a new system, without a resource that seems basic and already existed previously.
                                          The Recalbox team, formed by a small team, with extremely limited resources, which depends on the participation of volunteers who do not earn anything for it, and still distributes its system for free, deserves to be harshly criticized and constantly charged as if it were a case of life or death?
                                          It is not possible to understand when you are not the developer, when you have not been part of the development process, and have not analyzed the source code. If anyone finds a definitive solution in the source code, that doesn't affect more important features, please explain and tag any team members or active moderators.
                                          It's very easy to superficially analyze, not understand, and charge because you don't understand. Developing an operating system is extremely complex, developing code, testing, distributing it for free, and still being charged by someone who has already made it clear they don't understand, is demotivating.
                                          If you would like to receive an operating system for back-emulation for free, please appreciate it and support the team. Of course, we appreciate positive feedback, but we also understand negative feedback, as long as it occurs constructively, flagging issues and suggestions for improvement are welcome as long as they are done in a polite manner.
                                          If you just want to criticize, don't do it here, use your own social networks, because this space is also distributed for free by the Recalbox team, but it serves to clear up doubts from users, not for destructive criticism of the system being distributed for free with so much effort.
                                          Please don't think, "Just because it's free doesn't have to be bad," because that's not the point. The point is "It's free because the developers do it because they love retro-emulation and want to share it with everyone, and they try their best even for free", so how about acknowledging all the positives instead of just emphatically criticizing the points you don't like?
                                          Finally, to clarify better, the developer team is working on this situation, testing the possibility of hiding all games unless there is no game installed, which would solve the situation. But it's in the testing phase and I'm not a developer, so I can't say that it will be possible, nor when this feature will be released.
                                          But, it's not like it's been forgotten, it hasn't been resolved yet because it's not as simple as it sounds, especially when you have a small team that only works in their spare time and with limited resources.
                                            Scavy Global moderator @Alvin last edited by
                                            It's maybe a stupid decision, but it's a dev decision. If you delete all games, ES can crash and users would claim "i have deleted preinstalled games and it crashed". Man can think it's also a stupid decision. Wanting and coding are 2 different things.
                                            No problem to build a recalbox for children : you don't want Doom ? you select your doom game, you can hide it. So what ?
                                            A new time, where is the problem ?
                                            You can check it as you want, you can hide your games.
                                            On every release, we can read : wow this version is the worst, i prefer the older ones. Even on your so beloved v6 release.
                                            ES is like Pokémon, it's evolving. And evolved versions are more powerfull than the base one.
                                            Everyone can create the recalbox he wants : with former versions, with preinstalled games or not, with the pads he wants.
                                            BUT, the Recalbox someone is using is not the perfect Recalbox for another user.
                                            So, if the team has to choose the way to develop the project, users should just respect the team's choices.
