    7.2 can no longer pair 8bitdo SN30 pro+ controllers
    7.2 longer pair 8bitdo sn30
    13
    38
    11161
    • olivierdroid92
      olivierdroid92 Global moderator @erokx last edited by
      @erokx
      Did you remap your contrôler prior to launch a game?
      erokx 1 Reply Last reply Reply Quote 0
      • erokx
        erokx @olivierdroid92 last edited by
        @olivierdroid92 said in 7.2 can no longer pair 8bitdo SN30 pro+ controllers:
        @erokx
        Yes, I reconfigured controller after the successful pairing. Works fine with menus, but not games- some buttons work, others do not depending on the system.
        • olivierdroid92
          @erokx
          Can you please tel me what is you 8bitdo pad full name, FW and configuration with blue driver set with 'system driver' and not 'automatic"
          • lhari84
            lhari84 last edited by
            Same problem here: Controller pairs, but not working on Pi 3 B+. Other BT controllers work.
            Some question off-topic: How can I disable system „Ports“ on Recalbox 7.2? Already disabled „show included games“, but Ports will remain. Also when deleting those games from file system...
            Pi 4:
            Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
            Pi Zero 2W:
            GPi Case 2W, Recalbox 9.0
            • erokx
              erokx @lhari84 last edited by
              OK, my 8bitdo SN30 pro+ seems to be working now with an additional step, summary of actions:
              1. downgrade firmware to v4.01
              2. reset to factory settings (may not have to)
              3. change driver from automatic to "system"
              4. choose B+Start (Android pairing mode)
              5. once paired, config controller
              6. Select the SN30 pro+ as controller 1 (and unplug the controller/keyboard used in pairing)
                Once I completed all these steps, it started working. THANK YOU for all the help!!!!
              KoCinsKy 1 Reply Last reply Reply Quote 0
              • wastedthelight
                wastedthelight last edited by
                I had to pair mine after the update, but it works, no other issues discovered with the SN30 pro+.
                • lhari84
                  lhari84 last edited by lhari84
                  Sorry, I was confused with the model name too. I got the SF30 Pro (non +). It seems to be technically the same as SN30 Pro (non +).
                  Anyway, as mentioned before, I got problem the controller pairs but is not working at all - not even in ES/menu. I'm on latest firmware 1.34. Further not tried too much changing controller mode. It worked fine in "Switch mode" with Recalbox 7.1.1 and before.
                  Further one nice feature is, the controller switches off automatically when shutting down Recalbox when in "Switch mode", so I won't try again other modes at all as far as it might not necessary. In worst case I will restore my backup of Recalbox 7.1.1.
                  Anyway, thanks to developers for new version and the hard work!
                  Pi 4:
                  Pi Zero 2W:
                  LostOldman 1 Reply Last reply Reply Quote 0
                  • LostOldman
                    LostOldman @lhari84 last edited by
                    @lhari84
                    I am new to all of this, is there a place I can download version 7.1.1 again. I dont have a backup of it that I know of. I will for the versions in the future.
                    lhari84 1 Reply Last reply Reply Quote 0
                    • KoCinsKy
                      KoCinsKy @erokx last edited by
                      @erokx said in 7.2 can no longer pair 8bitdo SN30 pro+ controllers:
                      With this, my sn30 works.
                      • lhari84
                        lhari84 @LostOldman last edited by
                        @LostOldman
                        As far as I know, old versions are always replaced when new ones released. I recommend to backup whole SD card with a disk imaging tool before doing an update.
                        Pi 4:
                        Pi Zero 2W:
                        • lhari84
                          lhari84 @KoCinsKy last edited by lhari84
                          @KoCinsKy
                          Unfortunately this does not help for SF30 pro, as it pairs in general, but on the other hand Recalbox (even ES/menu) will not react in any way then.
                          Also controller setup will not find the controller even though it‘s paired, no button configuration possible too.
                          Pi 4:
                          Pi Zero 2W:
                          • lhari84
                            lhari84 @lhari84 last edited by
                            Update:
                            After restore of Recalbox 7.1.1, my SF30 pro controller works fine again, as expected.
                            Pi 4:
                            Pi Zero 2W:
                            • LostOldman
                              Update:
                              After a fresh install of 7.2, and my 8bitdo controllers work fine in B_Start mode in the main menu's but when I go to any game I have to turn off the controllers and then turn them on again to pair them. After that they will work in the games. The Hotkey does cycle through the shaders. I found an almost identical issue in the forums for version 7.0.1.
                              https://forum.recalbox.com/topic/22222/7-0-1-controller-works-in-emulationstation-but-not-in-retroarch
                              • lhari84
                                No one else having described troubles with Pi3 B+ and SN/SF30 pro (non+ version: https://www.8bitdo.com/sn30pro-sf30pro/)? Could it be just because of updating from 7.1.1 to 7.2? May a fresh install of 7.2 help?
                                Pi 4:
                                Pi Zero 2W:
                                  Scavy Global moderator @lhari84 last edited by
                                  @lhari84
                                  Known issues with SN30 pro, SF30 pro and SN30 pro + pads. It concerns firmwares of these pads.
                                  Here are the right firmware to use (tested et approved by beta-testers) :
                                  Appairing in android mode START + B :
                                  SN30 Pro -> firmware v1.33
                                  SN30 Pro + -> firmware v4.01
                                  SF30 Pro -> firmware v1.33
                                  Last firmware updates don't work fine. A fix is in progress.
                                  • lhari84
                                    lhari84 @Scavy last edited by lhari84
                                    @Scavy Thank you very much for info, great news that there's a fix coming up. Haven't seen any note in changelog, so I was not sure so far.
                                    Do you know if controllers turn off automatically too when shutting down recalbox, when in Andtroid-mode?
                                    Normally I always use 8bitdo controllers in Switch-mode, as I really appreciate this behaviour not having to turn off the controller separately 🙂
                                    If not, I will wait for the RB fix and/or 8bitdo fix instead of downgrading my controllers. Everything I need is running fine in 7.1.1 🙂
                                    Pi 4:
                                    Pi Zero 2W:
                                      @lhari84 my 8bitdo controllers turns off but not when i shut down recalbox but coz of the delay : 3 ou 5 mns after no use, they shut down.
                                      • Hurricane
                                        Hurricane last edited by
                                        Hi,
                                        I tried to install Firmware v1.37 (date 2021.07.16) on 8BitDo SN30PRO and it still doesn't work. Firmware version v1.33 also doesn't work for me. Can I ask for help?
                                        100.2k
