    Recalbox on PI4: how to hires N64
    recalbox pi4 hires
    1533
    • ralle211
      ralle211 last edited by
      I try to get hires textures to run for Super Mario 64 (N64).
      In my PI3b+ (Recalbox 6) I am able to set the Core in advanced emulator settings. In the Recalbox 7.1.1 the "core" setting is missing.
      Is there a reason why? How do I enable the hires textures?
      I copied the hires folder (in my case Super Mario 64) to the "hires_texture" folder and enabled the settings in the mupen64plus.cfg inside "/recalbox/share/system/configs/mupen64".
      Is there now more to do or do I have to set the core like Glide64, etc somewhere else?
        Zing Global moderator Translator @ralle211 last edited by
        @ralle211
        Have you tried to change the "emulator" (the name of the emulator and core are now in the same field)?
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/consoles/nintendo-64/textures-haute-resolution
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/consoles/nintendo-64/plusieurs-pack-de-textures-haute-resolution-differents-sur-le-meme-jeu
        • ralle211
          Thanks for the links.
          Yes I tried this already.
          But, on RECALBOX 7.1.1, I only have "mupen64plus" and "mupen64plus_nextgen" and "standard". Thats it. There is nothing with glide or rice in combination.
          In RECALBOX 6 there was an extra field for "core".
          Do i have to install RICE and GLIDE64 in addition?
          • RustyMG
            RustyMG last edited by
            From memory there was a mistake with the Pi4 build and some N64 cores were missed.
            I read this was to be fixed in v7. 2, but I read whats in that release and couldn't see the fix (maybe I just missed it)
            Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
            ralle211 1 Reply Last reply Reply Quote 0
            • ralle211
              ralle211 @RustyMG last edited by
              @RustyMG
              OH OK
              Than ill try with an 4GB version...
              I let you know if it works there
              RustyMG 1 Reply Last reply Reply Quote 0
              • RustyMG
                RustyMG @ralle211 last edited by
                @ralle211 said in Recalbox on PI4: how to hires N64:
                @RustyMG
                OH OK
                Hi, its not a 4gb version you need.
                Its either a slower Pi3 that has all the cores present, or wait for the 7.2 update for the Pi4 that should have the currently missing cores.
                7.2 looks to have a LOT of additions, so will probably be a while before being released.
                • ralle211
                  @RustyMG THANKS
                  I will do so
