    no wifi connection since today
    1151
    • chharti75
      chharti75 last edited by
      hi there.
      i'm not able to get a wifi connection since today..
      yesterday all worked fine, but today i have no chance to geht any wifi connection.. tried different routers etc.. i changed nothing..
      i see the router, and put in the password again, but still no wifi connection..
      anyone have an idea? i really dont understand this..
        Zing Global moderator Translator @chharti75 last edited by
        @chharti75 What is your hardware?
        What's your version of Recalbox (say the version, don't say "the last one")?
        Did you build your Recalbox yourself, or download a ready-made image from the internet, or did you buy everything ready?
        What have you modified recently?
        • DaRon
          DaRon last edited by
          Hi there.
          I have a WLAN issue with Version 7.1.1-Reloaded on the OGS.
          Not able to get a connection. I have two different WLAN-USB-Sticks, but they seems not working (no LED's are lighting).
          On other Firmwares WLAN is working normal - WLAN-Sticks are lighting after enabling WLAN in the system.
          Regards.
          Zing OyyoDams 2 Replies Last reply Reply Quote 0
            Zing Global moderator Translator @DaRon last edited by
            @DaRon I don't have the Odroid-Go Super, nor do I have the wifi adapter you're using, so I don't know how to help.
            You can open an isseu in gitlab, indicating exactly what you have already done, and the exact model of the adapter you are trying to use:
            https://gitlab.com/recalbox/recalbox/-/issues
              OyyoDams Staff @DaRon last edited by
              @DaRon only official WLAN dongle currently works with OGS.
              DaRon 1 Reply Last reply Reply Quote 1
              • DaRon
                DaRon @OyyoDams last edited by DaRon
                @OyyoDams
                Thanks for reply.
                I have a "Netis WF2123" (don't know which chipset) and a USB-WLAN-Stick with Ralink 5370 chipset. The Ralink 5370 is working with the OGS - but not with the current version of RecalBox.
                With other Operating-Systems my WLAN-Stick is working with the OGS. So it seems to be no Hardwareissue.
