    Power on/off button on OKDO Power-HAT Case
    GamePad/GPIO/USB encoder
    onoff button okdo power-hat case
    • NGC2264
      NGC2264 last edited by
      Hi all,
      I'm trying to get the power button working of the OKDO Power-HAT Case on the RPi4.
      On Raspberry Pi OS works with:
      dtoverlay=gpio-poweroff,gpiopin=18,active_low=0
      dtoverlay=gpio-shutdown,gpio_pin=17,active_low=1,gpio_pull=up
      I tried to put these lines in config.txt but does not work.
      An help would be appreciated, I'm not so expert on this kind of stuff.
      Thanks!
        Zing Global moderator Translator @NGC2264 last edited by
        @NGC2264 I don't know if this model is compatible, see if it helps:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/autres/ajouter-un-bouton-on-off-a-votre-recalbox
        • NGC2264
          @Zing I saw that and works fine with a generic push button, the problem is with this power hat.
          I think I have to edit something in /recalbox/scripts/rpi-pin56-power.py but I have no idea of what to change.
            @NGC2264 Sorry, but I don't have enough technical knowledge to help, the only content regarding this rpi-pin56-power.py script that I found was:
            https://forum.recalbox.com/topic/22366/carte-wm8960-et-bouton-on-off-pin56push
            • NGC2264
              Small step forward, in /recalbox/scripts/rpi-pin56-power.py I replaced GPIO from pin 5 to 17 and now by pressing the power button the RPi4 shutdown.
              Now would need to setup the power on and LEDs behavior.
