    recalbox not work well with DPI LCD on 4B
    recalbox dpi lcd
    9
    54
    12170
    • ian57
      ian57 Staff @DRAgon734235 last edited by
      @DRAgon734235 I think you need to use the fdmk overlay instead of the dmks overlay : here is may configuration for my 800x480 dpi screen
      temp_soft_limit=70
      dtoverlay=vc4-fkms-v3d
      # custom config
      [all]
      #3.5 HD tft screen 800x480
      dtoverlay=dpi18
      disable_overscan=1
      overscan_left=0
      overscan_right=0
      overscan_top=0
      overscan_bottom=0
      hdmi_force_hotplug=1
      #geekwrom
      framebuffer_width=800
      framebuffer_height=480
      #dtparam=spi=off
      #dtparam=i2c_arm=off
      enable_dpi_lcd=1
      display_default_lcd=1
      dpi_output_format=0x6f015
      dpi_group=2
      dpi_mode=87
      hdmi_timings=480 0 16 16 24 800 0 4 2 2 0 0 0 60 0 32000000 6
      #display_rotate=3
      DRAgon734235 2 Replies Last reply Reply Quote 0
      • DRAgon734235
        DRAgon734235 @ian57 last edited by
        @ian57
        I use recalbox-rpi4 7.1
        this is my code :
        max_framebuffers=1
        overscan_scale=1
        overscan_left=0
        overscan_right=0
        overscan_top=0
        overscan_bottom=0
        framebuffer_width=480
        framebuffer_height=800
        gpio=0-9=a2
        gpio=12-17=a2
        gpio=20-25=a2
        dtoverlay=dpi18
        enable_dpi_lcd=1
        #extra_transpose_buffer=2
        dpi_group=2
        dpi_mode=87
        dpi_output_format=0x7F216
        hdmi_timings=480 0 26 16 10 640 0 25 10 15 0 0 0 60 0 32000000 1
        dtoverlay=waveshare-28dpi-3b-4b
        The recalbox still stay at that recalbox logo picture always
        • DRAgon734235
          @ian57
          Your recalbox is 4.6 ?
          • ian57
            ian57 Staff @DRAgon734235 last edited by ian57
            @DRAgon734235 nop, 7.2 beta 🙂 do you have something connected on HDMI?
            DRAgon734235 1 Reply Last reply Reply Quote 0
            • DRAgon734235
              @ian57
              I have tried to connect or not connect HDMI LCD , the HDMI LCD not display
              they do not have any effect
              • ian57
                @DRAgon734235 here is my complete config.txt :
                # Boot loader configuration                                                #
                # Warning: do not edit this file as it will be overwritten when upgrading! #
                # Using /etc/modules is deprecated and no longer supported on 4.4 kernel
                # So manually enable audio
                dtparam=audio=on
                # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or
                # give a low resolution because tv had no enough time to initialize it
                boot_delay=3
                # disable boot rainbow
                disable_splash=1
                # default CEC name
                cec_osd_name=recalbox
                avoid_safe_mode=1
                kernel=boot/linux
                initramfs boot/initrd.gz
                # force hdmi while the tv can take time before sending the signal on the hdmi output
                # total amount of GPU memory
                gpu_mem_256=128
                gpu_mem_512=256
                gpu_mem_1024=448
                # your settings can be set in /boot/recalbox-user-config.txt
                include recalbox-user-config.txt
                # Raise the first security limit up to 70° instead of 60° for pi3 and pi4
                [pi3]
                temp_soft_limit=70
                [pi4]
                temp_soft_limit=70
                #max_framebuffer=2
                # custom config
                [all]
                dtoverlay=dpi18
                #geekwrom DPI 480x800 TFT display
                enable_dpi_lcd=1
                dpi_group=2
                dpi_mode=87
                #display_rotate=3
                • DRAgon734235
                  @ian57
                  thank you
                  where can I download recalbox 7.2 beta ?
                  I will try that
                  • ian57
                    @DRAgon734235 sorry you cannot it's development only actually
                    I think it will be soon released.I get this
                    • DRAgon734235
                      @ian57
                      OK , I will test when recalbox 7.2 beta come .
                      it is possible to rotate the DPI or HDMI LCD with 90 or 270 at recalbox 4B?
                      • ian57
                        @DRAgon734235 no not yep... even with new 5.10 kernels
                        did you see this https://www.waveshare.com/wiki/2.8inch_DPI_LCD there are specific overlays for this screen https://www.waveshare.com/wiki/File:28DPIB_DTBO.zip
                        I think you should copy them in the /boot/overlays directory and use the config from the wiki :
                        gpio=0-9=a2
                        gpio=12-17=a2
                        gpio=20-25=a2
                        dtoverlay=dpi24
                        enable_dpi_lcd=1
                        dpi_group=2
                        dpi_mode=87
                        #dtoverlay=waveshare-28dpi-3b-4b
                        dtoverlay=waveshare-28dpi-4b
                        • DRAgon734235
                          DRAgon734235 @ian57 last edited by DRAgon734235
                          @ian57
                          yes , I use that dtbo file from waveshare
                          I have tried that code , same
                          The LCD can display OK , but recalbox os can not enter Emulator
                          I think this is recalbox bug at DPI LCD,
                          • ian57
                            @DRAgon734235 in the code you post, you use dpi18 and not dpi24 which is the right one
                            which one are you using?
                            • DRAgon734235
                              @ian57
                              I have tried dpi18 and dpi24
                              they are same result
                              • ian57
                                @DRAgon734235 quite strange... works well here...
                                perhaps it comes from the 7.2 beta ... so wait and see 🙂
                                • DRAgon734235
                                  @ian57
                                  • ian57
                                    @DRAgon734235 actually with recalbox, no, sorry
                                    • DRAgon734235
                                      @ian57 😥 😢
                                      • ian57
                                        @DRAgon734235 Yes I know ! 😞
                                        • lulumix
                                          lulumix Banned last edited by
                                          BONJOUR,
                                          je pense avoir trouvais d ou veins mon problème
                                          je passe par (controllers gpio.enablec =0)
                                          je remplace le numéro 0 par1 ou 1.2 enregitrement
                                          je place la carte sd dans le rasb 3b+il se passe rien les boutons de ma bartop ne son pas reconnu je retire ma carte sd que je la remets dans l ordi (controllers gpio.enblec=0) il reste toujours sur 0 méme aprés un enregistrement
                                          je sais pas pourquoi il rest sur 0.
                                          merci de pouvoir me répondre car j arrive pas
                                          Zing 1 Reply Last reply Reply Quote -1
                                            Zing Global moderator Translator @lulumix last edited by
                                            @lulumix Please don't do SPAM:
                                            • https://forum.recalbox.com/topic/23465/controleur-gpio?_=1613931565428
                                            • https://forum.recalbox.com/topic/23398/problème-gpio-recalbox-7-1-1?_=1613847836893
                                            100.2k
