    Volume knob with raspberry Pi 3 & Recalbox
    knob recalbox volume
    • dapaze
      dapaze last edited by dapaze
      Greetings, I have a raspberry pi 3 running recalbox, I’m using some cheap 3.5mm plugin computer speakers into the pie audio jack, they work fine...I’d like to use this additional USB volume knob to control the volume because games have different volumes and it's just faster to control the volume:
      Volume Knob
      I plugged it in the opening USB port on the pi, restarted it, started a game with the sound on...and the volume knob did nothing.
      How can I control volume this way? Is this possible?
        Zing Global moderator Translator @dapaze last edited by
        @dapaze I do not have enough technical knowledge to be able to help you as you wish, but, I will try to answer considering what I know:
        • Its volume adapter, according to the description, works on Windows and MAC, and Recalbox is based on linux, so I believe that it is not compatible, due to the lack of drivers (if it doesn't even work on linux, it doesn't work on Recalbox).
        If you want to test other alternatives, these links may help you:
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/audio/codeur-rotatif-via-gpio-controle-du-volume-numerique
        • https://forum.recalbox.com/topic/4157/gpio-rotary-volume
        alexsunny123 1 Reply Last reply Reply Quote 0
        • alexsunny123
          alexsunny123 Banned @Zing last edited by
          @Zing said in Volume knob with raspberry Pi 3 & Recalbox:
          thanks my issue has been fixed.
          jackyjoy123 1 Reply Last reply Reply Quote 0
          • jackyjoy123
            jackyjoy123 Banned @alexsunny123 last edited by
            This post is deleted!
