    Can't connect from mac using SMB
    cant connect mac smb
    2701
    • dapaze
      dapaze last edited by
      I'm using the latest 7.1.1 download, and I'm trying to connect to recalbox via SMB://recalbox so I can use the web manager tool to transfer roms, and it won't connect using these steps:
      1. Looking at the Network settings in Recalbox, both the STATUS and IP ADDRESS are showing NOT CONNECTED.
      2. When I try connecting to recalbox on my mac using smb://recalbox, I get an error... "There was a problem connecting ..."
      I double checked that recalbox and my mac are sharing the same wifi.
      Francix alexsunny123 2 Replies Last reply Reply Quote 0
      • Francix
        Francix @dapaze last edited by
        @dapaze Hi, could you ping your Recalbox ?
        • sroach
          sroach last edited by sroach
          unless you put recalbox in your /etc/host table or in your routers DNS it's not going to know by host name.
          Try:
          smb://192.168.1.X/share
          what ever IP address you gave your recalbox, also like @francix said, can you ping your recalbox?
          I am pretty sure you need the wifi to say connected in the menu, try turning wifi off, reboot and then turn in on and connect and see if it connects.
          one connected then try
          Apple Key + K
          smb://192.168.1.10/share
          Also, looking at your post you need the "/share" at the end of your smb mount command.
          • dapaze
            Well that's the thing, I don't have an IP address showing in the Recalbox Network Settings Menu. It says STATUS: NOT CONNECTED. How do I assign an IP Address to recalbox?
            How do you ping a recalbox?
            dapaze 1 Reply Last reply Reply Quote 0
            • dapaze
              dapaze @dapaze last edited by
              @dapaze Nevermind, got it. Wrong password was the cause. I can connect via SMB.
              • alexsunny123
                alexsunny123 Banned @dapaze last edited by
                @dapaze said in Can't connect from mac using SMB:
                thanks my issue has been fixed.
                alexsunny123 1 Reply Last reply Reply Quote 0
                • alexsunny123
                  alexsunny123 Banned @alexsunny123 last edited by
                  This post is deleted!
