    Request: Stella2014 for Pi 4
    request stella2014
    1096
    • jorgemagana
      jorgemagana last edited by jorgemagana
      Hello, could be it possible to add Stella2014 core or emulator for Raspberry Pi4? This emulator makes possible play games like Tac Scan and Demons to diamonds. It is present for Raspberry 3b, but not for Pi 4 Recalbox version. Thanks.
        paradadf Staff @jorgemagana last edited by paradadf
        @jorgemagana hi! If it isn't present it is just an overlook. We use the stella (stella2014 is outdated). I'll add it in case it is really missing.
        Or you mean stella2014 can play some games the stella can't?
        jorgemagana 1 Reply Last reply Reply Quote 0
        • jorgemagana
          jorgemagana @paradadf last edited by
          @paradadf Thanks, yes, stella2014 can play some games that stella can't.
          • Secamfr
            Secamfr last edited by
            @jorgemagana Wich games ? Just for curiosity...
            jorgemagana 2 Replies Last reply Reply Quote 0
            • jorgemagana
              jorgemagana @Secamfr last edited by
              @Secamfr said in Request: Stella2014 for Pi 4:
              Tac Scan, Deamons to diamonds.
              • jorgemagana
                jorgemagana @Secamfr last edited by jorgemagana
                @Secamfr in the Stella, stand alone documentation says:
                "Controller.SwapPaddles"
                "Indicates that the left and right paddles in a particular port should be swapped. This is used for ROMs like 'Demons to Diamonds' where the default paddle is paddle 1, not paddle 0. Other ROMs such as 'Tac-Scan' default to paddle 3, which can be set using both 'Controller.SwapPaddles' and 'Console.SwapPorts'. The value must be Yes or No."
                But this parameter is not present in retroarch version.
                But in Raspberry pi 3, selecting Stella2014, I can play Tac Scan without problem... the problem is that I do not have my rasp 3 anymore.
                • barbudreadmon
                  barbudreadmon @jorgemagana last edited by
                  @jorgemagana pretty sure it's unintentional that stella2014 supports those games while stella don't, you should report the missing settings to the author
                  Libretro developper :
                  • FBAlpha FBNeo (Arcade)
                  • Kronos (Sega Saturn/ST-V)
                  • YabaSanshiro (Sega Saturn)
