    USB Keyboard Encoder "Dual Strike" ArcadeForge
    GamePad/GPIO/USB encoder
    usb keyboard encoder dual strike arcadeforge
    4730
      Zing Global moderator Translator @SmashDde last edited by
      @SmashDde
      I am still hoping for "the magic update that fixes this" but ...
      I am sorry for the problem you are facing, but unfortunately there is no magic involved: there is only the hard work of a small team of developers working hard to serve as many users as possible, but without having all the possible hardware.
      @jonas
      Time to try another retrogaming distro.
      It is a pity to hear that, but unfortunately I cannot give a date for the problem to be solved, I can only suggest that you support the issue that was opened by @SmashDde :
      https://gitlab.com/recalbox/recalbox/-/issues/1434
      If you check it out, you'll notice that there are another 192 issues open, and the team is doing its best.
      SmashDde 1 Reply Last reply Reply Quote 2
      • SmashDde
        SmashDde @Zing last edited by
        @Zing Hey there. Don't get me wrong, please - I am sure, everybody involved is doing their best to bring the project forward. And I know that your problem does not get recognized or pushed top priority just because you've reported it. No way 😉
        On the other hand, if you (as a user) are stuck with something for months, more often than not with the added passion of a personal DIY project, it gets frustrating when there's seemingly nobody actively into solving it.
        I think everybody does understand the pov of the users in this as well?!
        Zing 1 Reply Last reply Reply Quote 1
          @SmashDde Of course, we understand the pov of a frustrated user because there is a bug, and as a user, I fully understand how bad this is.
          I just wanted to make clear the situation of the developers, and to make it clear that if more users comment on your issue it will be
          better: the team of developers is small, and the work is a lot, so they need to prioritize, and one of the priority criteria is the number of users affected.
          100.2k
