    HDMI audio not working Recalbox x86 (Optiplex 390)
    Emulator Arcade/PC/Console
    390 audio hdmi optiplex recalbox
    • Punkrockrobot
      Punkrockrobot last edited by Punkrockrobot
      Thanks for such an amazing program and community. This is a first time build, and while I tried retropie I simply love the superior ease of use with Recalbox and am so happy with my Raspi 4 build that I decided to try to upgrade to an x86 machine.
      Specifically I have
      Recalbox x86_64 bit
      SSD 240gb
      Dell Optiplex 390 mobo
      G630 CPU (lga 1155)
      GTX 750 GPU
      It outputs to an older monitor just fine, but the audio isn't coming in. I tried the audio jacks on the mobo and it works just fine, and I would consider the work around of just plugging a cable between the audio jack on the pc and the monitor, but the interference is very noticeable and makes the audio unbearable.
      I'm thinking there is a conflict between the built in sound card on the Dell Optiplex motherboard and Recalbox?
      I searched for a config file to switch the audio to HDMI=2 to force the audio to the HDMI but I didn't see a config.txt file like you would with a retropie build. Is there something that is equivalent?
      Thank you for any help you are willing to give.
      • Pitch64
        Pitch64 Staff last edited by
        You should give a try at this method, that could help you 🙂
        https://forum.recalbox.com/topic/21453/recalbox-7-plus-de-son-en-hdmi-pc64/44
        Next release? Soonâ„¢
