    Xbox One S Controller: UNABLE TO PAIR CONTROLLER
    GamePad/GPIO/USB encoder
    xbox unable pair
    • bemandrill
      bemandrill last edited by
      Today I have burned the Recalbox 7.01 and I cannot pair my Xbox One S Controller. It is shown in the BT devices list, but when I select my controller always I get the same error:
      I have checked with two different Xbox One S controllers, and they properly work by USB cable, but I cannot connect them via BT.
      Before, I always have played with these controllers vua BT... Any idea?
      Sureshot 1 Reply Last reply Reply Quote 0
      • Sureshot
        Sureshot @bemandrill last edited by
        @bemandrill Start your pad the first time with start+B (not start+x).
        bemandrill 1 Reply Last reply Reply Quote 0
        • bemandrill
          bemandrill @Sureshot last edited by
          @Sureshot thank you for your answer, but I dont undertand it.
          I press HOME buttom to turn on my Xbox One S controller, and then the pair button. I have never press combinations as Start + B or + X, but I tried and it stills not working...
          • bemandrill
            bemandrill @bemandrill last edited by
            I saw this post https://forum.recalbox.com/topic/17312/bluetooth-testers-wanted
            but when I reboot, it reposts N and not Y...
              Zing Global moderator Translator @bemandrill last edited by
              @bemandrill To disable ertm it is easier to change the value of the line in recalbox.conf:
              controllers.bluetooth.ertm=1
              to
              controllers.bluetooth.ertm=0
