    Trouble installing rclone
    trouble installing rclone
    1928
    • Adrian Ubed Matta
      Adrian Ubed Matta last edited by
      Hi,
      i tried to install rclone in recalbox 7.0.1 but when i change permissions in a file the change is not applied.
      im in the shared filesystem.
      In addition, i want change the rw permisions in all filesystems forever, how can do this?
      • Secamfr
        Secamfr last edited by
        @Adrian-Ubed-Matta Hi, share partition is exfat, so you can't use permissions on it 😕
        You must install rclone in system partition /usr/bin/ or /recalbox/share_init/
        • Adrian Ubed Matta
          @Secamfr said in Trouble installing rclone:
          thanks, but i have more troubles.
          unzip -o -j -d rclone-tmp rclone.zip
          Archive: rclone.zip
          error: invalid zip file with overlapped components (possible zip bomb)
          i cant unzip any file
            you need to unzip before transfert.
            codaa 1 Reply Last reply Reply Quote 0
            • Cyril92
              Cyril92 last edited by
              Great Idea I see new features to easily transfer / save games to the cloud. New feature for RB 8.X ? 😉
              System : Raspberry Pi 3b /Pi 4b
              Box : NespiCase (Pi3b) / Nespi4case (Pi4b 2Go)
              Peripheral devices : SSD Samsung 970 Evo 1To
              1 Manette 8bitdo SN30 pro+
              1 Manette compatible PS3 Shanwan
              Je teste la 8.0-Beta1
                Hello
                https://forum.recalbox.com/topic/13840/tutorial-how-to-sync-saves-roms-to-the-cloud?_=1603900713296
                • codaa
                  codaa @acris last edited by
                  @acris I had the same problem with a completely unrelated zip file, the unzip command appears to be broken.
                  Your answer suggests that it may be broken "by design", isn't it a bug though ?
                    @codaa
                    more information please ?
                    you need to unzip on your computer before
                    and transfert file after.
                    share_int is a read partition.
                    • codaa
                      @acris I am trying to unzip a zip file into /root folder and I am facing the same error message :
                      I can unzip the file correctly on my laptop so I don't think it is the issue. It's a zip file generated and downloaded from github : https://github.com/pimoroni/fanshim-python/archive/master.zip
                      So my guess is that the unzip command has a problem.
                        @codaa merci d utiliser ton sujet intial . Je te le redis en français
                        la partition root est en lecture si tu veux faire des manipulations il faut la passer en écriture. et il est conseillé de dézipper sur son pc et de transférer les fichiers ensuite. Recalbox est minimaliste.
