    Solved Cannot flash Recalbox 7
    cannot flash recalbox
    • thehaze34
      thehaze34 last edited by
      I am unable to flash Recalbox 7.0 to a SD Card using BalenaEtcher.
      The process always stops with a message "Something went wrong. If it is a compressed image, please check that the archive is not corrupted."
      I tried two different 32GB SD Cards.
      I tried Balena Etcher Portable Versions 1.5.60 / 1.5.70 and 1.5.109
      I tried Recalbox images for Rpi3 and Rpi0, downloaded them several times.
      I keep getting the same error again and again.
      The etcher software and the SD cards seem to be OK, because flashing the old Recalbox 6.1.1 or other images work just fine.
        Zing Global moderator Translator @thehaze34 last edited by
        @thehaze34 You can try:
        • https://recalbox.gitbook.io/tutorials/utility/flashing-an-image/unetbootin-tutorial
        • https://recalbox.gitbook.io/tutorials/utility/flashing-an-image/rufus-tutorial
        • RASPBERRY PI IMAGER
        • thehaze34
          Thank you.
          Seems like Rufus did the job. At least it finished without error message and the installation screen is now running on my GPi 🙂
          Still strange that etcher works fine with other images, but doesn't like RB 7.0
