    Buy a Pi4 or Not??
    buy pi4
    7
    8
    1210
    • sroach
      sroach last edited by
      Hello All,
      Congratulation on the new release!
      I was able to successfully move all my ROMs and Configurations over with easy and everything is up and running RB 7 on my pi 3 b+
      Here is my question, if I am mostly playing MAME, NES, SNES emulators which seem to be fine on the 3b+
      Would you guys recommend buying the pi4?
      paradadf Zeke 2 Replies Last reply Reply Quote 0
        paradadf Staff @sroach last edited by
        @sroach imo, if you can play all the games you want on your rpi3, there is no need to buy a more powerful board.
        • Zeke
          Zeke @sroach last edited by Zeke
          Hello @sroach,
          RPi4 it very better mostly for Nintendo 64, Dreamcast and PSP πŸ˜‰
          PC x64 MSI X399 SLI Plus
          AMD Threadripper 1900X
          64GB Corsair Vengeance 3200Mhz
          EVGA GeForce GTX 1060 6GB
          Recalbox sur Western Digital Blue SSD 500Go M.2 (boitier USB-C 3.1 Gen.2)
          Ο†(k) ∝ At
          • Space81
            Space81 last edited by
            Naomi Sega it's avaible in recalbox 7 for rpi3/4 ?
            Pitch64 1 Reply Last reply Reply Quote 0
            • Fefo81
              Fefo81 last edited by
              Is it enough to buy RP4 with 2GB? Or is it better 4GB?
              Cheers
              • Pitch64
                Pitch64 Staff @Space81 last edited by
                @Space81 said in Buy a Pi4 or Not??:
                Naomi is available on rpi4 πŸ™‚
                @Fefo81 said in Buy a Pi4 or Not??:
                Cheers
                2GB is enough πŸ™‚
                Next release? Soonβ„’
                • Fefo81
                  Thank you very much!
                  • SkullGrin
                    SkullGrin last edited by
                    4GB and especially 8Gb seems like overkill. Has anything on Recalbox EVER needed that kind of Ram? Highest i'd go on a Pi would be 4GB. 8GB and up should be reserved for the Next generation.
                    Copyright Β© 2021 recalbox.com
