    Recalbox 7.0 issues, network, scraper
    7.0 network recalbox scraper xu4
    • Paulska
      Paulska last edited by Paulska
      I'm on a xu4
      I'm having issues placing games on my 7.0 build.
      Wired connection, on my computer I am able to see recalbox computer in my network (windows 10)
      In Windows 10 I also have SMB/Linux client enabled
      When I click on recalbox error died up that is unable to access.
      I do have access manager through recalbox.local and can upload games that way but it is a pain in...
      scraper is not working. Message at the end says could not find target game. I uploaded about 100 N64/snes games, find it hard it couldn't even match one.
      Every so often I keep getting message ,
      Update is available and then the text in that message looks like a bunch of html code.
      Is anyone running this on xu4 and having the same issues?
      Thank you
      • ian57
        ian57 Staff last edited by
        @Paulska for 1. did you try directly th IP adress of your recalbox \192.168.1.xxx or \recalbox in the explorer?
        1. this is a bug on the xu4 and only xu4. don't upgrade and deactivate upgrade message in ES
        Paulska 1 Reply Last reply Reply Quote 0
        • Paulska
          Paulska @ian57 last edited by Paulska
          @ian57
          okay i think it has to do with my computer and windows 10.
          dont have other windows 10 machines to try it out.
          i tried on windows 8 on my laptop to join ````\\192.168.1.9`` the ip of the recalbox and it went in fine.
          scraper thing i will still try to figure out.
          • ian57
            ian57 Staff @Paulska last edited by
            @Paulska try skraper https://www.skraper.net/ the best one 🙂
            • Paulska
              Network Problem solved.
              Incase someone else can not get access to the shared recalbox folder. Found solution online from
              link text
              Basically RUN>gpedit.msc>Administrative Templates>Network>Lanman Workstation>Enable insecure guest logons>enable.
              I am now able to see the network share.
              This had been killing me for a while with windows 10 LTSC. Hope this helps someone out.
